Sway bar end links ... OUCHHHHHHHHHHH
Old Nov 23, 2012 | 08:26 PM
Mints33's Avatar
Ok, I'm in the process of swapping out my sway bar end links, have done some research, and didn't think it was going to be such a huge deal. Ok, the car is a 2000, got some rust underneath, of course, but it actually doesn't look that bad. BUT the nuts are caked on there!!! The bottom nuts, started to turn under some major torque, then it came to a complete stop, and stripped, both sides of course. At least there was a little bit of room, to fit a saw blade, cut those suckers off, no problem. And now, the top ones, F@@@! The nuts rounded off, did Nissan make these out of alloy or something? S!!T, I mean they're softer than crap. Spent enough hours on those suckers, getting the batteries charged for some drilling action tomorrow night. Hopeufully it'll finally come out. I am tired, a long day at work, then more bs w/ the car. Anyhow, thanks for letting me vent.
Old Nov 23, 2012 | 08:47 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Someone didn't soak them
Old Nov 23, 2012 | 09:42 PM
Mints33's Avatar
I've used PB blaster and Liquid wrench ... neither worked!
Old Nov 23, 2012 | 10:45 PM
Rods03Max619's Avatar
DAMN THAT Sucks....GL Tomorrow....
Old Nov 24, 2012 | 07:13 AM
StevieB's Avatar
I've had good success when I lock a visegrip on the inner hex portion right inside the rubber boot and an impact gun on the outer. If you don't have an impact then visegrip the inner and heat the outer nut with a propane torch and go at it with a ratchet.
Old Nov 24, 2012 | 12:02 PM
Quickywd01's Avatar
This is the best thing that I've found so far.
Old Nov 24, 2012 | 03:27 PM
knight_yyz's Avatar
Toolie
zip cut
cjandura's Avatar
cut dem bishes off bra! then when you put the new MOOG ones on make sure you get 8 hardened flatwashers to prevent front end clunk.
Old Nov 24, 2012 | 04:33 PM
chrome91's Avatar
torching them off is the easiest way
Old Nov 24, 2012 | 08:28 PM
Mints33's Avatar
Thanks for the tip bro, but I got OEM ones, heard some clunking issues w/ the MOOG, so OEM is the way to go for me. Don't need to do this twice. lol
Old Nov 24, 2012 | 08:40 PM
Mints33's Avatar
UPDATE: Thanks for the tips guys, I thought about torching the crap out of them, but was too afraid to accidentally torch my brake lines, and/or abs lines. My cordless drill and reciprocating saw did the trick, spent the evening battling her out, but came out on top in the end.
Impact wrench, I need one of those, I have a cheapie one, I think that's what rounded off the first nut. Had a wrench on the back side, the impact wrench on the front side, thought the nut broke lose when she finally spun, but instead, the nut rounded off.
POLL: Should I attempt to do the outer tie rods while I'm at it???
Old Nov 24, 2012 | 08:58 PM
chrome91's Avatar
if youre scared of heating something up, take a clean rag and soak it in cold water and put the rag on brake lines or whatever
only thing is have a bottle of water close by, the rubber part of the endlink sometimes will catch fire a little bit
Old Nov 26, 2012 | 07:59 AM
Finchum's Avatar
I replaced my lower control arms last week and I used a correct fitting 6 point/sided socket for the nut, wd40/pb blaster combo, breaker bar, crescent wrench on the endlink inner, and a hammer to knock the breaker bar down in "impact" fashion. both came loose just fine.
but I did notice they are of a soft material. My endlinks come today, so hopefully the sway bar side cames loose just as easily.
Old Nov 26, 2012 | 08:53 AM
02pearlmax's Avatar
The sway bar side bolts seem to be the more troublesome ones. Make sure you have a perfect grip (vise grips worked well for me) on that inner bolt or else it will round off pretty much instantly. I rounded the inner nut off on my passenger side using an open-end wrench and this is how it looked after 2 hours of chiseling.
Good luck and don't screw up like me.
Old Nov 29, 2012 | 07:05 AM
Mints33's Avatar
I will take a pic of mine later tonight, it was NOT fun taking those suckers off!!! What are you all using for a replacement???
Old Nov 29, 2012 | 07:43 AM
Finchum's Avatar
replaced mine yesterday. they came off just fine with my technique of wd40/pb blaster, then hammering the ratchet while a crescent wrench held the back side. but this is a southern lived car that probably only saw road salt a handful of times.
Old Nov 29, 2012 | 09:33 AM
02pearlmax's Avatar
I used Moog endlinks and Moog bushings.
Old Nov 30, 2012 | 08:47 AM
Finchum's Avatar
^i went moog as well. endlinks and tierod ends from amazon.com
Mar 12, 2020 12:06 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
Stagnet04
Sep 14, 2015 11:28 PM
