airbag warning light keeps coming back
Old 12-04-2012 | 08:15 AM
dozu's Avatar
2001 SE 5SP
every time I reset the light, it would stay off for 1-3 days, then come back on.... and seems it always comes back on a few seconds after I start driving.
I can get to the 'diagnosis mode' following the FSM, but I never get a code using the self diagnosis method..
so what to do now? it's a nuisance to reset it every few days..... and if I go to somebody with Consult II, will that make a difference? can Consult II pull something that self-diagnosis cannot?
Old 12-04-2012 | 09:43 AM
user name001's Avatar
No consult || wont make a difference in clearing the code, but if your using a cheap generic tool the consult will at least help you to determine what air bag sensor is faulty, has there been an acciedent recently that set off the airbag light? Have you had the seats out? You either have a connection problem or a bad airbag sensor, i think befor just trying to clear it, you should figure out what sensor is triggering it, there are a few different sensors so find the culprit befor trying to just clear the light.
Old 12-04-2012 | 12:54 PM
dozu's Avatar
no accidents.
the only thing I can think of is the day before it went on the first time, I changed the starter motor, but can't imagine that has anything to do with the airbag.
what did you mean by 'cheap tool'? I did the self-diagnosis following the FSM, in the RS segment.
I guess at this point there is really nothing I can do..... I am hoping the symptom actually gets WORSE so I can catch it in diagnosis....
I did visual inspection of the sensors (crash zone, and them sensors under the seats, nothing eye-catching)... never took any seats out of the car either.
Old 12-04-2012 | 01:10 PM
The best thing you can do is take it to a shop and have them run the SRS code, it will determine which airbag crash sensor is triggering the light, And go from there.
Old 12-04-2012 | 02:20 PM
maximaboy12's Avatar
did you do anywork at all near the glove box? there is a plug there that if you unplug your sensor will come on as well.
Old 12-05-2012 | 09:18 AM
dozu's Avatar
my question is what can Consult II read that self-diagnosis can't.... matter of fact right now the light is off, so I don't think the shop can read anything out of it..... yes?
Old 12-05-2012 | 09:19 AM
dozu's Avatar
did change the cabin air filter once, but that was months before the light came on the first time.
besides, if it were a unplugged sensor, the light would be on ALL THE TIME.
Old 12-05-2012 | 11:31 PM
gapboi210's Avatar
You got a light, get the code pulled, go from there. Easy...
Lakersallday24
03-20-2024 12:22 PM
Lakersallday24
06-16-2019 02:35 AM
King_Ten_Ahead
09-30-2015 05:27 PM
Gsantos79
08-08-2015 08:41 AM
Tanvirkamal
08-05-2015 02:32 AM
Quick Reply: airbag warning light keeps coming back
