direct fuse box grounds
Old Dec 12, 2012 | 11:13 AM
  #161
NmexMAX's Avatar
dot dot dot ...
Any dyno graphs?
  #162
rebelhell's Avatar
Originally Posted by Aviation005
i tested it and proved it works
Proved to whom? We're also still waiting on your dyno results to show us all the mad HP you've gained.
Old Dec 12, 2012 | 11:14 AM
  #163
Mr. Brett's Avatar
Originally Posted by NmexMAX
Any dyno graphs?
Ohai!
How's da Paffy?
Old Dec 12, 2012 | 11:17 AM
  #164
Number-Four's Avatar
O rly?
I have gone through 2 140amp main fuse on my boosted car. Blown a few fuses that was attached to the brake lights that actually turned out to be a bulb had shorted out and re-welded itself together, fuse saved massive repair. Blown the cig lighter once. Those 2 were on the DD.
Not only that i work at an autopart store you wanna know how many blown fuse issues i have seen daily? It's VERY common and also very relieving to know you have only blown a fuse and dont have a huge repair on your hands.
Now listen to what im saying, you have wired your car so that if there is a small short the safe guards in place to prevent small shorts turning into big problems you have bypassed. Small shorts and voltage spikes blow fuses, a voltage spike can come from....umm lets see.....oh you have an aftermarket radio, sub and amp, when you turn those things up and in the duration of whatever music you listen to its going to cause spikes in both amperage and voltage.
i second this ive worked at a shop and we have had numerous cars come in with blown alt fuses
Old Dec 12, 2012 | 11:18 AM
  #165
Amerikaner83's Avatar
if the ground points dont help at all, why the *** is my guage cluster 2x as bright after adding them. why is my car more responsive??
thisss is why im making a big deal, master electrician or not, your WRONG
i cant explain it any simplar
i added each wire and test drove after each, each ground MADE A DIFFERENCE
once again idc if u do it for a living, i tested it and proved it works
I'll make this simple for you. Ready?
Your crappy lights were, to you, a baseline of performance. Doing what you did helped. But your "baseline performance" is what is known as SH!TTY GROUNDING!!! And that's POOR PERFORMANCE to the rest of us.
Now, your car is acting a lot better...so to you, that's a huge performance gain. But to us it's called NORMAL. Your grounding situation was sh!tty to begin with.
Welcome to normal.
Old Dec 12, 2012 | 11:20 AM
  #166
Maverick4189's Avatar
iPhones are hard to type on brother.
Old Dec 12, 2012 | 11:22 AM
  #167
Originally Posted by Maverick4189
iPhones suck, and are hard to type on brother.
fixed
Old Dec 12, 2012 | 11:23 AM
  #168
foodmanry's Avatar
Da Roller Coaster!
Yes...since they automatically provide suggestions for misspelled words and automatically capitalizes the first letter of each sentence after a period. Of course you have to enable those settings (by the way they are enabled by default so you must have turned them off if you don't have them enabled). Very difficult indeed...
I have an iPhone and do just fine by the way...
  #169
Mr. Brett's Avatar
Only thing I WILL give the iPhone over the Droid is that its autocorrect dictionary is a little sharper. And the keyboard is a bit more accurate.
Other than that. Still love my Galaxy S2 more.
Old Dec 12, 2012 | 11:24 AM
  #170
Crusher103's Avatar
Another question do you honestly think we are just picking on you because you are new? that everybody on this forum has just come down on you INCLUDING the mods. That we were just waiting for you to come through the door and **** it we gonna azz rape his post.
We are trying to stop you from ruining your car. If you fry your ECU thinking you are the best and most resourceful electrician that's ever lived, its a +$2000 to get a new ecu and no you cannot run to the junkyard to get an ECU for any maxima 99 on up. You have to go to through the dealer and you have to get it reprogrammed.
So just listen, no grounding makes any maxima faster, just makes its electrical system a little bit more stable and that only really helps if you have sh1tty grounding to begin with, its just placebo that your feeling. Save yourself the trouble that its going to cause later on and take those wires off the positive side of the battery. Thats just asking for trouble.
Old Dec 12, 2012 | 11:25 AM
  #171
rebelhell's Avatar
Galaxy S3 with Swype FTW.
  #172
foodmanry's Avatar
Da Roller Coaster!
Still waiting for theses scientific manors of testing and resulting data. Please amaze me...
Old Dec 12, 2012 | 11:26 AM
  #173
foodmanry's Avatar
Da Roller Coaster!
I'll take my paid for (thank you company) iPhone...
Old Dec 12, 2012 | 11:28 AM
  #174
rebelhell's Avatar
I second the paid for part. I get $200 every two years and $85 a month for my Samsung. Just sucks I can't root because I am stuck using Good for Enterprise.
Old Dec 12, 2012 | 11:29 AM
  #175
Mr. Brett's Avatar
I have Swype on my S2 as well. I'm not really a fan of it...haha. I prefer the old chicken-peck method with my thumbs. Swype is good for sending quick texts when you're driving or otherwise busy. Which...I'd never, ever do something like that.
My buddy just picked up an S3. Both phones are awesome. The S3 doesn't really seem to have any improvements over the S2, though, short of a slightly faster processor. I upgraded my S2 to ICS as soon as I bought it, and it's just as reliable as my buddy's S3.
Now I'm waiting for Jellybean to come out for the S2. I know it's already out for the 3...
  #176
Crusher103's Avatar
I will be shocked if it turns out to be actual manors for testing.
Old Dec 12, 2012 | 11:30 AM
  #177
Mr. Brett's Avatar
Oh okay.
Well you win this time.
Old Dec 12, 2012 | 11:32 AM
  #178
rebelhell's Avatar
Yeah, my GF has the S2 and the only real difference seems to be a slightly thinner profile and slightly larger screen. That and the 4G that's not available in my area yet.
Old Dec 12, 2012 | 11:36 AM
  #179
CapedCadaver's Avatar
Call me Wookiee Goldberg
the chassis isnt a conductor? hahahahah dude your retarded
stop trying to write big paragraphs with big words to gain credibility
The point in my picture where R1 and R2 meet does not need to be a conductor as long as the battery connects to the chassis "somewhere" (as a conductor). The chassis will only be used for conducting electricity from other remote chassis grounds (on other circuits) are needing to get back to the battery.... but not for the engine-to-chassis-to-battery cables.
Old Dec 12, 2012 | 11:38 AM
  #180
Mr. Brett's Avatar
4G LTE ftw.
Sadly, the 4G on my S2 is faster than my home internet...
I don't think the S3 is really any thinner. Honestly, with the case off my S2, I can barely tell it's in my pocket.
  #181
Crusher103's Avatar
SHUT UP U HO, U JUS' USIN' DEM BIG WORDZ N ****!!1!2!
Old Dec 12, 2012 | 11:39 AM
  #182
Mr. Brett's Avatar
Crusher.
Old Dec 12, 2012 | 11:40 AM
  #183
Crusher103's Avatar
waT?
Old Dec 12, 2012 | 11:41 AM
  #184
you dont understand my logic at all. yes drilling a hole wont change much.
neither do you
take 2 pieces of sheet metal. use 1 bolt to hold both together. measure resistance
now wait ten yesrs for the bolt to rust
remeasure resistance
guaranteed gain in resistance
the unibody rusts and increases resistance throughout the entire car
your bonus question is unjust, I dont care for r1x3.4523 + R2D2 = luke skywalker
You say adding two negative to chassis will not change anything, you are wrong. I have TESTED it
you say the chassis is not a conductor, WRONG
you take everything I say, mold it to something different, then elaborate on it to try to make me look small
all this form cares about is telling everyone how wrong they are.. well keep telling me cause I find it amusing
I put everthing I said to the test and idc if your an electrical engineer, tunermaxima, or luke skywalker, everything I have been saying makes sense and works amazing
Using "two (2)" ground cables makes no difference. Reducing the resistance makes a difference, which is what you achieved by using 2 cables. But you could just as easily have use one (1) 0GA wire to get the same result. Naturally when you are using 4GA wire to do a man's job, you're going to need to use it in more than one place because it's not all that thick.
And your "guaranteed gain in resistance" is the bolt's fault (well really your fault for not keeping your shiit clean and maintained), not the chassis' fault. If you keep everything clean, the resistance of the chassis (between any 2 points on the chassis) will never change with any multimeter you can afford unless you are measuring it FROM a rusty/dirty point. If you measure from shiny metal to shiny metal it will never change.
But the metal under the rust and under the paint (especially the thick frame rails) is so abundant and plentiful that you'll break the car in half from a lack of structural integrity before you have an issue passing electrons across it. Which giving your lack of interest in math and science, you probably have no idea what an electron is.
  #185
Crusher103's Avatar
Conductor is a big word.....
  #186
It's been a while, but is that a Plymouth Fury, or a Dodge Polara?
1986 Dodge Diplomat. You were close.
Old Dec 12, 2012 | 11:43 AM
  #187
Crusher103's Avatar
And your "guaranteed gain in resistance" is the bolt's fault, not the chassis' fault. If you keep everything clean, the resistance of the chassis (between any 2 points on the chassis) will never change with any multimeter you can afford unless you are measuring it FROM a rusty point.
all dem wrdz b 2 big man.
  #188
Mr. Brett's Avatar
:metalmax:
Old Dec 12, 2012 | 11:45 AM
  #189
when the expert is wrong, theres a problem.
when the amateur is stupid enough to think the expert is wrong, there's a problem.
I have an experiment for you tho.. replace EVERY fuse in your car with a nice thick piece of jumper wire, since as we all know, fuses have resistance inside them. Then install the biggest amp and subwoofer you can find, and run it off your windshield wiper circuit. Then sit back and enjoy the show.
  #190
rebelhell's Avatar
4G LTE ftw.
I guess you're right... S2= 0.33" S3= 0.34" lol
I love my home internet. I'm one of the lucky ones. Phone's 3G sucks azz though.
Old Dec 12, 2012 | 11:46 AM
  #191
litch's Avatar
This is better than shark week.......
  #192
NmexMAX's Avatar
dot dot dot ...
Ohai!
How's da Paffy?
http://forums.maxima.org/other-cars/643154-ohai-2.html
Old Dec 12, 2012 | 11:47 AM
  #193
Mr. Brett's Avatar
Oh. Durr.
Reading comprehension > me.
Old Dec 12, 2012 | 11:48 AM
  #194
OMG THERE IS NO FUSE ON THE ALTERNATOR TO POSITIVE LINE OMG OMG
now im trolling hahahah
is there an easy way to directly ground the alternator without having to remove its main bolts/ac compressor? I would have loved to ground it, but I cannot find a place
i drew a picture of YOUR car sorry i forgot the dryer duct but it was intended to be an exploded (no pun intended ) view not a plan (something you don't understand the concept of) view.
and idfk man, i dont work on 4th gens or 4th gens or whatever the **** you have. But the electrical concepts don't change from car-to-car unless you end up with a positive ground car from the early 20th centry, or a car running a 6v system or a 24v system... 12v-with-negative-grund is pretty well understood by the rest of us tho.
Old Dec 12, 2012 | 11:49 AM
  #195
Crusher103's Avatar
I will pay $100 right now to see this. I really would.
Old Dec 12, 2012 | 11:52 AM
  #196
merovi's Avatar
You stuff is brighter because you fixed a problem with your ground. Congrats, you have a normal brightness gauge cluster. Same for responsiveness, it is now normal.
I have added a grounding kit to my car and also removed it. I have alot more in my car that would make me feel a difference in the butt dyno like you are talking. The difference is just not there. What you are feeling is a fix to your problem.
I had a similar feeling when I fixed my MAF for the first time. I had never driven the car with a working one. It was like a whole new car. Difference is I didn't come here and tell everyone replacing my MAF with a new one made it faster and more responsive. It made my car normal again.
Also you don't have a cold air intake. A cheap short tube on ebay and a filter from autozone will give you more gains that that awful laundry system you have. Unless you funnel that tip OUTSIDE of the engine bay you will always be getting warm air. I don't care what you say. That is why you don't see many true CAI for our car and the ones you did see required drilling past the battery to put the intake into the wheel well.
:metalmax:
replace swype with swift key flow though. it's still beta but my god its great.
Old Dec 12, 2012 | 11:53 AM
  #197
We are clearly dealing with a profession here, he even goes to walmart to buy batteries.....
and instead of worrying about "grounding"(which what you are doing is not) your brake fluid need to be flushed and changed.
i'm going to have to call pot-kettle for suggesting brake work to someone whose car is in a marginal state.
Old Dec 12, 2012 | 11:59 AM
  #198
No you moron, you dont get it. The first time your car has a voltage spike which happens from time to time, in all cars even the best running cars experience spikes. EVERYTHING is gone. EVERYTHING. Not just your alternator or light bulb, EVERYTHING. By the time you are done repairing all that has been shorted out and/or blown up you will understand because its going to be a $6-7k bill vs 3 dollars and a trip to autozone for a fuse.
you mean if his voltage regulator crapped itself at high RPM?
Old Dec 12, 2012 | 12:05 PM
  #199
Nah, its just the people on here like to say NO and WRONG and its a game to me now hahahah this is fun
why would people buy into something that works? hmmm
i never said your upgrades "don't work". I said that you don't understand much of the things involved in how it worked, how you could have done it differently (and more safely) and still had it work, and the idea that just because it works now doesn't mean it will work forever.
Case in point, a guy with a Porsche 911 who was trying to be a backyard mechanic decided to experiment with his car's timing. He bumped it up a little bit, the car got faster. He bumped it up some more. Car got faster again. He was so excited how he was seeing real and immediate results from his modifications. So he cranked the timing up further still and the car was like a stabbed rat, greased lightning, a bottle rocket in july.
Until it started running rough and performing poor a few weeks later... then he took it to a trained mechanic (my friend and former coworker). Mechanic pulled out the spark plugs, which ALL had their electrodes burnt into nonexistence. Mechanic replaced his plugs, set the timing back to stock and said "don't touch it again". If you want a faster 911, buy the Turbo.
Old Dec 12, 2012 | 12:07 PM
  #200
Scientific manor...the place where Chemistry cat lives
