alternator misdiagnosed as faulty
Old Dec 13, 2012 | 10:06 AM
scotcando's Avatar
My 2002 max.lost power and died due to low battery voltage Told I needed to replace alternator
Will cut a long story short. It turned out to be a poor connection at the plug that goes into alternator beside the main cable connection This will cause the alternator to stop charging and not let the battery warning lite activate
I removed and cleaned the connector with contact cleaner now everything is ok
I found this out by following the diagnostic procedure 1 in the charging system section of the electrical FSM
Hope this helps some of you to avoid wasting money on unnecessary replacing an alternator
ps prior to this I had experienced the battery light sometimes flickering when driving
Old Dec 13, 2012 | 11:15 AM
2damax's Avatar
Yeah this is sort of common sense but it is awesome to see a new user post something a little useful!
A couple of weeks ago the same thing happened on my 04 passat. Mechanic wanted $800 to R/R. I took it out and the plug snapped. $50 later all was well.
Old Dec 13, 2012 | 11:46 AM
TunerMaxima3000's Avatar
Such a common mistake! No one thinks to check the wiring and fuses, everyone just points at the component.
NICE WORK dude.
Old Dec 13, 2012 | 05:10 PM
Maxgig's Avatar
it would have been very easy to assume it was the alternator, good catch.
TallTom
57
Oct 14, 2025 05:16 PM
Max8
Sep 22, 2015 02:53 PM
