2K2 CAI Available
Old Jan 10, 2002 | 08:11 AM
studman's Avatar
2K2 CAI Available
I called PlaceRacing.com today (626.334.3345) and they told me they had finished their CAI for the 2K2 Maxima. Just thought you should know. They are available in Red, Yellow, and Blue for around $200, and in Silver for around $210. Shipping is extra ($15-50 based upon type - UPS only).
Old Jan 10, 2002 | 08:22 AM
bigbadboss101's Avatar
Interesting... something else to think about...
Old Jan 10, 2002 | 08:24 AM
soundmike's Avatar
Very sound, Mike
Re: 2K2 CAI Available
Cool! Thanks for the heads up!
Old Jan 10, 2002 | 10:38 AM
mattattax's Avatar
THX
Old Jan 10, 2002 | 10:44 AM
swallac2
Make way ignorant white trash here....What is a CAI. We ain't got those fancy things on our Camaros/Firebirds.
Seriously though what does it stand for, I come from a Firebird.
Old Jan 10, 2002 | 10:52 AM
BigDogJonx's Avatar
a true CAI is a COLD AIR INTAKE. Now Place Racing CAI's are made so that the 3" piping is long and increases the velocity of the air going into the engine. Creating "sort of" like a ram air effect. Plus in their kit, you have to drill a 3" hole in the inside fender wall so that the Cone filter sits behind the plastic wheel well protector. This way it gets possibly the MOST coldest air possible. Cause anything from the engine bay or around there is going to be HOT from the engine.
Colder the air, the better for the engine.
Dixit
Old Jan 10, 2002 | 11:42 AM
02MaximaSE's Avatar
PRCAI FRANKENINTAKE?!?!?! DECISIONS DECISIONS hmmm, whats better?
Old Jan 10, 2002 | 11:59 AM
swallac2
Dixit
Ah yes, in Musclecar land we call that Ram Air or as you say Cold Air Intake. I had a homemade version on my '87 IROC back in high school, sounds just like the same thing.
Thanks for the enlightenment...
Old Jan 10, 2002 | 12:03 PM
NmexMAX's Avatar
dot dot dot ...
Now to see Dynos comapring both PR's setup and Frankens setup.......interesitng.
Old Jan 10, 2002 | 12:07 PM
Jon91SE's Avatar
Pusssseeeehhhh
History has shown CAI, thats what i would get..........
Old Jan 10, 2002 | 12:17 PM
Do you think CAI will void the warranty? The dealer told me Stillen will not void the warranty. He cannot tell me if other aftermarket maker's intake would or would not.
Old Jan 10, 2002 | 12:20 PM
NmexMAX's Avatar
dot dot dot ...
If it requires drilling a hole, it may void the warranty, maybe if you could cover the hole, and take it in whenever it needs warranty work.
Old Jan 10, 2002 | 12:32 PM
soundmike's Avatar
Very sound, Mike
Out of stock
Called up PR and they say it's out of stock. Either they didn't make a lot of there's a whole lot of 2k2 people out there that's buying them out.
Old Jan 10, 2002 | 12:42 PM
MaxRPM's Avatar
Void the warranty on what? The Fender?!
Old Jan 10, 2002 | 12:44 PM
freeze2k2's Avatar
Hehe exactly.
Old Jan 10, 2002 | 01:00 PM
2001SE's Avatar
you can't know what stories Nissan's serivce can make....
Old Jan 10, 2002 | 01:55 PM
NmexMAX's Avatar
dot dot dot ...
yeah, my drive belt broke and they tried blaming it on my lowerering springs, saying that the fron end of the car must have scraped on something, which caused damage to the drive belts.
Old Jan 10, 2002 | 02:13 PM
Weasel's Avatar
Dynos never show the full advantage of a CAI. At speed, the CAI sucks in cold air from outside whereas the underhood intake uses hot air. Dynos are usually done with the hood open, so the underhood intakes create a bit more power than in the real world. Without the high-speed air being fed into the CAI filter like it would be at speed, the CAI dyno will read slightly lower than its real-world potential.
Bottom line: you can't know the full difference unless you drive or ride in cars with both, or compare 1/4 mile times under the same conditions.
Old Jan 10, 2002 | 04:03 PM
02MaximaSE's Avatar
TRUE
Old Jan 10, 2002 | 04:29 PM
NmexMAX's Avatar
dot dot dot ...
I stand corected, so then I would like to rephrase that and say: I would like to see the same car with the 2 different intakes run on the same day at the track, to compare its respective times with each intake of course...There we go!
Old Jan 10, 2002 | 09:04 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
with a CAI and the long long tube it has, esp with a high revving engine and the thirst for air like a 255hp 2k2 it get starved for air above 5K rpms and won't perform as well. some people say that you loose low end power with a pop style. look at my dyno. i started around 2k for a reason to show no loss with my intake. i'd be warry of breathing problems with the PR CAI with a car with a big thirst for air that only breathes marginally above 6k as it is.
Old Jan 10, 2002 | 10:51 PM
irvine78's Avatar
no..the paint..
TallTom
57
Oct 14, 2025 05:16 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
Sep 27, 2015 08:37 AM
A32goldylocks
Sep 16, 2015 01:33 PM
lowpost99
22
Sep 2, 2015 04:38 PM
