Can FSTB cause Body Flex???
Old Nov 10, 2000 | 11:47 PM
2000MaximaSE's Avatar
I put my fstb on about a week or so ago. I noticed somthing today i never noticed before. The gap between the upper side of my headlight and the right fender on the passenger side lookes pretty big... Like over a 1/4 inch...
I could even push it in towards the head light to like 1/8"
Was the car always like this or did my fstb cause it??
If my fstb did cause it what do i need to do to it short of taking it off.
It does look like a bigger gap than the gap on the driver side.
Help me out, im worried
Adam
Old Nov 11, 2000 | 12:41 AM
MaximaZero's Avatar
Needs non-Maxima Friends
i dunno, but u might wanna make sure the bar's adjusted correctly..
Old Nov 12, 2000 | 04:45 PM
ander
Send me your bar.
Just send it to me.
(Check torquing specs if it comes down to it)
Old Nov 12, 2000 | 06:20 PM
Groundcntrl
when ander is done with it send it to me to test it out.
Old Nov 12, 2000 | 06:25 PM
Groundcntrl
by the way you are one lucky *** seventeen year old. just remember dealing crack will get you nowhere.
Old Nov 12, 2000 | 08:14 PM
bullseye's Avatar
Adam
You're not doing any "Dukes of Hazard" stuff with the car, are you? Like jumping rivers and sh*t? If not, then there's no way you'd get that kind of deflection, FSTB or not. Had to be a pre-existing condition...
Old Nov 13, 2000 | 09:27 AM
Dany's Avatar
Nope, your bar is fine. The gap is what we call a great build quality...
I have the same thing on my Max, before and after the FSTB.
Nissan Maxima is build very poorly: rattles, uneven gaps, etc......
Oh well.
Enjoy.
Adam
Old Nov 13, 2000 | 02:05 PM
proudowner's Avatar
Re: Nope, your bar is fine. The gap is what we call a great build quality...
As a new owner with plans to add these upgrades to my max 01 AE, should i worry,have a professional install or do it myself.
Oh well.
Enjoy.
Adam
Old Nov 13, 2000 | 03:08 PM
Dany's Avatar
I just installed the Stillen FSTB.
Took about less than an hour.
If you have torque wrench it will be better.
And hope your AE Max is better build than my 2000 SE.
Good luck.
Old Nov 13, 2000 | 03:14 PM
Shingles's Avatar
The missing moderator
Re: Re: Nope, your bar is fine. The gap is what we call a great build quality...
No, it's an easy job. BTW the bar is doing it's just... I suspect that it might not have been there before because the body was flex'd?
-Shing
Oh well.
Enjoy.
Adam
Old Dec 12, 2000 | 07:42 PM
bry2kse's Avatar
Just a quick thought.. make sure you installed the bar while on flat pavement.
Also.. go to sears.. but a low end torque wrench.. it's a good tool to have.
Old Dec 12, 2000 | 10:35 PM
Maxima95GLE's Avatar
How did you install the FTSB?
Did you jack up your car when you installed the FTSB? And was the pavement flat when you installed? If you either installed it w/ your car jacked up (thus causing some chassis flex) or on uneven pavement (again, some chassis flex resulting), and then lock up the nuts, your car will stay in that flexed posiition--thus the gaps that may have resulted from the install. Try this, park on a flat driveway or garage, remove the FTSB, and reinstall it.
REDinLV
Aug 15, 2024 12:30 AM
bumpypickle
Sep 20, 2015 08:22 AM
Jamie Bolus
Sep 13, 2015 05:56 PM
