Need some help!! p0300
Old Jan 1, 2013 | 05:25 PM
nishansMaxima's Avatar
yes i have the dreadful p0300 code. Came on today along with p0152. what im wondering is..how these two codes effect one another. would o2 sensor throw a code for a multiple missfire? I kinda have an idea whats going on there but i would really like your input in on this..also i had a p0147 before but went away. i need a new maf soon.
Old Jan 1, 2013 | 07:53 PM
DennisMik's Avatar
The P0300 misfires are causing raw fuel to be pushed through the exhaust system and the O2 sensors will report problems from a too rich fuel mixture. Fix the P0300 and the O2 codes should go away.
Old Jan 1, 2013 | 09:15 PM
i have no idea what could have caused it to have a missfire..i changed the plugs about 2-3 months ago. OEM nissan plugs from the dealer. i only have 60k on the car
also scanner read that the o2 sensor had a high voltage. guessin thats shot..
Old Jan 1, 2013 | 09:41 PM
tosheto's Avatar
Bad coils
Old Jan 2, 2013 | 12:51 AM
BronxSleeperMax187's Avatar
no code yet for which cylinder is misfiring, so I would wait till it shows up....hows the car driving, is the ses light flashing constantly? Coil IMO too
Old Jan 2, 2013 | 07:53 AM
DennisMik's Avatar
Until you fix the P0300 code, don't worry about the O2 sensor code, it may go away because there is too much un-burned fuel in the exhaust system. If you want something to worry about, worry about your catalytic converter. The catalytic converter is burning all that un-used fuel and will "wear out" the converter prematurely and it will plug up, requiring replacement.
If the ECU doesn't give codes for specific cylinders, you may have to replace all the coils.
Old Jan 2, 2013 | 05:30 PM
I have no cats. Obx headers and y pipe, gutted cat n that's it.
Old Jan 2, 2013 | 05:51 PM
2damax's Avatar
If you replaced coils recently and now have a code then it is likely the coils. Gotta figure out which one now. How does the car run?
Old Jan 2, 2013 | 06:53 PM
ive replaced OEM nissan plugs from the dealership about 3 months ago. coils i never did.
The car runs like **** usually on a cold start. sounds like a tractor then the CEL will blink, and stay steady. after it warms up a little, the idle catches it self and the car runs great.
im frustrated with this man.
Old Jan 2, 2013 | 07:15 PM
2damax's Avatar
O I misread sorry. Are you sure you did the plugs right? Maybe it is time to check the coils. Any oil in the cylinders during the plug change? What is year/mileage again?
Old Jan 2, 2013 | 07:35 PM
DennisMik's Avatar
The CEL light blinks when the misfires are occurring. But spark plugs will not cause a CEL. There are at least 3 coils failing, otherwise the ECU would give specific codes.
Old Jan 3, 2013 | 09:48 PM
no oil on the plug when i changed em. 2002/68k
Old Jan 4, 2013 | 04:53 AM
2damax's Avatar
Wow you are kind of lucky to have no oil in bank 5. Try letting the car idle. While it misfires pull one coil at a time. If there is not change then that coil is bad. You will only be able to pull the front coils while doing this.
Old Jan 4, 2013 | 08:08 AM
AoD11's Avatar
Also your exhaust should stay still while your car is running, if it shakes back and forth that is usually a sign of a bad coil.
Old Jan 4, 2013 | 05:30 PM
Ghost_54's Avatar
Whats the condition of your oil, .ie too low?, old and needs changing? P0300 can also be caused by the oil level getting to low or very dirty and the very narrow passage way in the "Varible Timing Solenoid" getting sludge or other impurities getting blocked up in the passage way.
Old Jan 5, 2013 | 08:52 PM
i changed the oil 1500 miles ago. full synthetic.
this is so frustrating!!
Old Jan 6, 2013 | 05:28 AM
2damax's Avatar
Do you burn oil? Did you check front plugs by pulling.
Old Jan 6, 2013 | 09:39 AM
MaxinO2's Avatar
I had the notorious PO300 code for over 2 years and never figured it out to the end.. It wasn't my coil's, injectors, vacuum leak, faulty valve cover.. None of it. It was a piston ring going bad the whole time which created bad compression with leaded to a random multiple misfire.. This is the worst thing that could happen to a Maxima by far.. I had to replace the engine
wyche89
125
Nov 25, 2011 10:14 AM
Grand_hustle17
Dec 28, 2009 12:20 PM
abakalen
18
Jun 7, 2008 01:51 PM
PlanoSER
Aug 9, 2007 05:04 AM
MAXRB8
Feb 28, 2006 11:15 AM
