FOB key for a 5th gen???
Old 01-07-2013 | 04:49 PM
method2madnesss's Avatar
I'm fan of flip FOB keys and figured I had to have one for my Max. I ordered one on eBay for $17.95 with free shipping. It doesn't look cheap at all looks real genuine like an OEM. But all I had to do was just transfer my original remote, buttons, battery, and transponder chip in to the FOB key and voilą. I just took it to a local locksmith and had the key cut for $4. All in all I think it's MUCH appealing than the standard key and remote. Just something you don't see everyday...
Old 01-07-2013 | 05:15 PM
tseng1023's Avatar
interesting, i'd like to do this. how long did it take to swap everything over?
Old 01-07-2013 | 05:50 PM
Literally took me less than 5 minutes. Do you have both the stock key with the transponder chip (blue thing at the bottom of key) & the oem 4 button remote?
Old 01-07-2013 | 05:54 PM
tseng1023's Avatar
Old 01-07-2013 | 06:17 PM
Do you have transponder chip in your key? If you do then check these out they're from the same seller I got mine from...
FOB Key #1
FOB Key #2
Old 01-07-2013 | 06:32 PM
tseng1023's Avatar
FOB Key #1
FOB Key #2
I mean it works like a factory key does so I'd say so? Which one do you suggest I buy and what do i do about the one without buttons
Old 01-07-2013 | 06:45 PM
cjandura's Avatar
Just get an alarm and remote start with smart start so you can use your iphone to start and monitor your car from anywhere
Old 01-07-2013 | 06:47 PM
tseng1023's Avatar
Been wanting to do this for a while! I got the hook up too!
http://viper.com/P-5704V/Viper-5704-...e-Start-System
Old 01-07-2013 | 06:54 PM
cjandura's Avatar
Do the 5904 with iDataLink bypass and the 556t window module and smartstart.the 5904 has a better external shock sensor and the idatalink bypass works better then the directed xk05 and you dont need a extra key for either
Old 01-07-2013 | 08:37 PM
To be SAFE I'd go to the dealer to have them confirm there's a transponder chip in the key or the remote. If you don't have one you should get the 1st one I listed since images on you buttons have worn off. Then when you get the FOB key unscrew it apart and take the blank key to a locksmith and have them cut it for you and then you can reassemble everything (putting your remote parts into the FOB key)
MAXSE5SPD
09-17-2022 05:00 AM
QueensMAX
09-15-2015 05:14 AM
Violator
09-09-2015 11:14 AM
carid
09-09-2015 06:06 AM
Lowered_a33
09-01-2015 08:49 PM
