1st Oil Change
Old Jan 10, 2002 | 06:42 PM
samiam5345's Avatar
1st Oil Change
Anyone know when a good time to change oil is after break in, I figured at about 1k, and then regularly after that. Also what type and weight oil would you suggest. Any thoughts? Thanks
Old Jan 10, 2002 | 08:58 PM
Menasor's Avatar
Check your owners manual. it tells you in there. I personally use mobil 1 also you may want to use an OEM oil filter or mobil 1 filters, even napa filters are good or i should say are constructed very well believe it or not. The fram filters are not made very well contrary to what some people believe. i am taking an automotive class and we learn about this stuff yesterday. Good luck.
Old Jan 10, 2002 | 09:36 PM
emax02's Avatar
Re: 1st Oil Change
I just did my first oil change at 1100 miles{quaker state and Nissan filter}. I plan on doing my next change at 3750 and then 6750 and then I plan on switching to amsiol sythetic and a amsoil filter at 8000 miles.
Old Jan 10, 2002 | 09:50 PM
mrmick's Avatar
1st oil change
I changed my oil at 1900 and used 5w30 valvoline.Next time I might put in synthetic.I'm a mechanic and we use valvoline in alot of motors and after many miles the ones with valvoline look spotless inside.
Old Jan 10, 2002 | 11:04 PM
Menasor's Avatar
Re: 1st oil change
I was wondering, what are the API ratings on the Valvoline that you use?
Old Jan 10, 2002 | 11:07 PM
irvine78's Avatar
Re: 1st Oil Change
i heard it's good if you change oil in your first 1000 miles..but then again...nobody can tell u when to do the first oil change..i didn't do my first one until 3,500miles.
just do it whenever u feel like it..
Old Jan 11, 2002 | 05:33 PM
mrmick's Avatar
Re: Re: 1st oil change
It is API/SL It says on label it exceeds API services SL/SJ
Old Jan 11, 2002 | 05:36 PM
ZIPPIN's Avatar
Mauja He Mauja
Re: Re: 1st Oil Change
praise the lord
cruce91
Sep 20, 2015 10:23 AM
wingnut2006
Sep 19, 2015 06:13 AM
97_GXE
20
Sep 17, 2015 08:12 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
