Has anyone compared the 2k2 Altima V6 Adn the 2k2 Maxima head to head?
Originally posted by craaaazzy
here's the one for the 2k2 w/ stillen intake.
http://forums.maxima.org/showthread....threadid=90192
Numbers are very close...closer than I expected.
I'm surprised that the Max actually dynoed at 3 HP less...even if it were simply environmental/equipment differences, the power/torque difference between the two engines would not be significantly different.
Thus, you cannot directly compare the numbers.
The fact that the auto Max dynoed so close to the manual Altima tells that the Max 3.5 is actually making more power than the Altima 3.5.
Originally posted by madmax2k
One car is an auto (the Maxima) and one is a 5 speed (the Altima.)
Wow, this question pops up about every 2 days now. DMBMaxima dynoed his 2k2 6 speed and it put out roughly the same hp and tq as the 5 speed Altima (within 2%). It is now pretty much agreed that the Altima and Maxima are making the same power manual to manual and auto to auto.
Dave
Dave
Dave
Dave
a) The engine puts out 240HP in both cars. The Nissan automatic tranny in the Maxima is far better than it was the previous year losing only 15% (whereas it used to lose 25%). The Max however has more torque than the Altima. This means that the automatic Max is just as fast as the stick Max and the stick Altima.
b) The engine puts out 255HP in the Max and 240HP in the Alty. The 6 speed manual is a tad lossy (20%).
c) The engine puts out 240HP in both cars. Ehughes Stillen intake added over 20HP and over 20ft-lbs of torque.
d) The engine puts out 255HP in both cars. All of Nissan's tranny's are absimal with 25% losses. The Max however has more torque than the Altima. This means that the automatic Max is just as fast as the stick Max and the stick Altima.
e) Both cars have 255HP. All the tranies have horrid losses 20%+ for the sticks and 30%+ for the autos. Ehughes Stillen intake added over 20HP and over 20ft-lbs of torque.
and of course all of these theories (except for B) assume that Nissan is openly and blatantly lying to everyone.
Stereodude
Originally posted by Stereodude
Agreed on by who? I've yet to see a proper Dyno of an auto Altima. So what we know so far (from dynos) falls into one of the following categories.
Stereodude
Stereodude
Stereodude
Stereodude
i think B is about right
OK...I just found the 6 speed dyno plot.
So, what this looks like is that a 2002 6 speed stock puts down the same peak power as a 2000-2001 5 speed with a Y-pipe and CAI.
However, although the peak whp isnt improved all that much, the powerband is much wider on the 2002. A 2000-2001 with the 2 basic mods will make the same peak power, but only at 6400-6500 rpm. The 2002 makes close to 200 whp for about 1500 rpm. This should make for a much faster car.
Strangely enough, the 2002 torque curve looks alot like a 4th gen torque curve. The values are just higher.
jskirwin
Jun 8, 2016 08:49 AM
soon2ownmax
Aug 13, 2015 02:19 PM
