Vibration under acceleration only
Old Jan 31, 2013 | 08:13 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
having this problem, wondering what could be. I have replaced all front end and looking to see whats going on. The car has new tires, balanced and aligned. Engine mounts are brand new, but "ONLY" when I accelerate the car the vibration is there. I havent replaced the Tranny mount and I think is broken. Could that be?
thanks
Old Jan 31, 2013 | 08:56 AM
NmexMAX's Avatar
dot dot dot ...
Could be. Are you talking about the rubber mounts attached to corssmember or which tranny mount?
Nice to see you;'re still around!
Old Jan 31, 2013 | 08:59 AM
TallTom's Avatar
Are you lowered and if so, how low are you? It could be axles.
Old Jan 31, 2013 | 09:07 AM
NmexMAX's Avatar
dot dot dot ...
Maxspeed springs from his cardomain. My car has been lowered on a combination of both Tien S and Progress for the lat 80k, and my axles are fine.
The only time I ever saw shaking under acceleration was when my tires were shot to poop.
I'd say inspect mounts and do the ten and two and six and twelve.
Old Jan 31, 2013 | 10:41 AM
02whitemaximase's Avatar
Also, what brand axles do you have? I have the GSP axles and they are known to have vibration only under acceleration. It is because they don't have that rubber counterbalance rubber dampener bushing on the middle of the passenger side shaft.
See this thread for details:
http://forums.maxima.org/5th-generat...-pictures.html
Old Jan 31, 2013 | 11:03 AM
Lontar1's Avatar
the axels were replaced 3 weeks ago before I relocated to PA. Before that the vibration was there still. I wonder what could be then. The tranny has a rubber mount to hold it right? I know there is one....lol, or I could be losing my head.....
Old Jan 31, 2013 | 11:08 AM
Lontar1's Avatar
Im still around was away from the forums, but I stil have the maxima and planning on keeping it until it dies. It recently did a 4 thousand mile trip from PA to Florida 4 times and no issues. i was teh one in pain after the trips, lol.
[/QUOTE]
Old Jan 31, 2013 | 06:22 PM
LA02MAX's Avatar
I still have my money on the axles even if they were replaced....aftermarket axles are known to produce vibration with maximas for some reason, my friend went through several with the same results until he finally had his OEM one remanufactured. I finally found a "good" aftermarket one with no vibration but it turns out the boot clamp fell off, leaked all the grease and now, 3 months after replacing it it's back to vibrating when applying throttle....it has to be some flaw in the suspension design, because this shouldn't be that difficult.
Old Jan 31, 2013 | 09:51 PM
RobertColianni's Avatar
If you're getting a loss of HP, too, it's a Multi-Cylinder Misfire from bad Coil Packs.
Old Feb 1, 2013 | 05:26 AM
Lontar1's Avatar
No los on HP the engine is working fine. I can say that when I put in R the car makes a noise and when I put in D it makles a louder noise. Like a "crak" noise, I did apply the brakes and accelrate the car with the brakes applied and I heard a "crack" noise like something broke in the engine.... but cant tell what it was.
Does anyone knows a good mechanic in Philadelphia, someone that wont rip me off?
Old Feb 1, 2013 | 06:00 AM
TallTom's Avatar
I know of an awesome alignment shop in Delco (Broomall) that can probably help.
Mickey's Alignment in Lawrence Park Industrial Center.
Old Feb 1, 2013 | 07:25 AM
Lontar1's Avatar
http://www.youtube.com/watch?v=3MfkxKXwQGQ
Im new to the area and have no knowledge of places yet. Can you give me an address? I see you are from NYC but Im in Philly.
Old Feb 1, 2013 | 07:45 AM
TallTom's Avatar
I was born and raised in philly for 41 years. I only moved to NYC last year.
Mickeys Suburban Alignment
950 Sussex Blvd
Broomall, PA 19008
It's in Delaware County. It's about 5-10 minutes off the Blue Route exits (I-476).
I was there a few months ago getting an alignment and wheels balanced. I prefer to go there instead of shops in NYC. They seem to treat me better and their equipment and techs are top notch.
I found out about the place when my old mechanic told me that's where the local garages take customers cars. I was originally going to recommend my old mechanic, but think that his quality of work is slipping.
Old Feb 1, 2013 | 11:37 AM
Lontar1's Avatar
950 Sussex Blvd
Broomall, PA 19008
Thank you for your response and help. I will see how far that location is from me. I just found a place that fixes car alarms (they just fixed my Viper 791v) and they have another place for light mechanic so Ill how it goes with them, if I dont like how they treat me $$$$$ Ill find another one.
Old Feb 1, 2013 | 12:18 PM
TallTom's Avatar
What town or part of Philly are you currently in?
Old Feb 1, 2013 | 03:11 PM
Text me. 610 761 1842.
Old Feb 1, 2013 | 03:30 PM
user name001's Avatar
Shot in the dark here, torque converter? Maybe its shaking around at certain RPM's . Can you pinpoint the cracking noise? Maybe get someone to engage gears while you listen.
Old Feb 1, 2013 | 07:44 PM
Lontar1's Avatar
Im in Shawmont Avenue, close to Main Street
Old Feb 2, 2013 | 06:46 PM
TallTom's Avatar
OK, Roxborough. You're about 25 minutes from the place if you plan on going. I-76 west > I-476 south to exit nine and it's about 5 minutes off the exit.
Old Feb 2, 2013 | 08:02 PM
cjandura's Avatar
Heres a shot in the dark make sure your driverside axle is all the way in sence you just did/had front end work done i remember when i did struts along time ago i popped one out and didnt reseat it all the way in and it came out on me while driving.
Old Feb 11, 2013 | 04:18 PM
Emmbro's Avatar
I just bought and installed the MasterPro Select halfshaft from O'Reilly on my Maxima and am having the same vibration under acceleration.
I did notice that the new one doesn't have the same counterbalance that the OEM one had. I almost looked into trying to figure out how to take it off and put it on the new one, but decided against it (didn't know it was a counterbalance since it just looked like some rubber piece). Now I'm wishing I did.
Any guesstimates on how long this will last before destroying the brand new hub and wheel bearing I also just put in?
user 11122324
42
Jul 18, 2022 03:35 PM
HOKUSMAX
Nov 13, 2017 04:34 AM
D Mason
Jun 21, 2016 04:43 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Need help
23
Oct 2, 2015 08:56 AM
