After installing radio
After I installed my radio I realized my clock and my auto seats weren't working. I checked the mirror fuse and it's fine and my radio is working fine can someone please tell me where the fuse is for the auto seats or what to look for I'm lost I have a 2003 max TE 6 speed. Thanks everyone !
The fuse that powers the power seats also powers the windows, the door locks, the sunroof and couple other things. I am assuming these other things work, otherwise you would have mentioned them. So this is not a fuse. You could have messed up the wire harness, but it is not under the dash. It runs along the rocker panel and then goes sideways under the seat.
The clock uses 2 fuses. Fuse #1 (that also powers the mirrors and is used by the radio) is used for displaying the time. Fuse # 12 is used to keep the time. So what is the clock not doing - lighting up or keeping time?
Did you use a nissan specific wire harness or did you cut and or splice into the harness? I dont have access to alldata right now but it is possible that something is tied back. lots of times incorrect wiring of the dimmer or illumination wire in Nissans causes strange issues. Also make sure your ground is a fresh ground to chasis for the radio. Also something to consider, I dont remember what wire but there is a wire in the factor radio harness that must be grounded in order to retain functions such as trip and odometer. I thought the wire was limited to that but having always connected it, I cannot speak to what else might not work as a result. Search will be your best friend here.
