Opinions needed...speedometer upgrade....
Hey there folks, just curious, I was tinkering around with the idea of upgrading my speedo in my 2k Max GXE with either an SE speedo or the I30 speedo.....what do you all think? Will both connect up perfectly??? Never done it before, just wanted to get you kind folks opinions...Thanks!
I30 swap will be a lot of work .. If thats the route you wanna go prepare to spend a lot of time on it.
I put the 2001 AE cluster in my 4th gen SE took many many hours figuring out the diagrams not plug and play at all.
Yall do know Surratt posted a repin that alows you to swap the clusters right all you have to do is swap the wires around
You can re pin almost anything to make stuff work he asked for plug and play.
The anniversary edition cluster is simply an SE cluster, no different. The AE was only offered in the SE trim.
All SE 00/01 gauges are that style. Just fyi
Pics of it in the 4th?
I always liked the SE 4th gen gauges, but the 5th are nicer for sure
About the SE gauges, cool info.. had no idea what was what on the 5th gens. I know they called them AE cluster, that happened to be the one I liked for my 4th gen.
Nice, good work! That's how I'd have done it also I think, repinning requires pins, and 'proper tools' to do correctly. Waste of time/money, IMO, solder/shrink tube like you did I say.
Still waiting for pics
Tuner im surprised at you bro! You know there is a $5 pin extractor tool and all your doing is swapping pin locations around on the harness connector not the cluster.man were going to have to come up there and slap some of that canadian out of you again!
Ah....just a clip of one wire and it would all work, even when the headlights come on? The abs, oil, airbag and so on light up, tach revs properly already. Could you walk me through this??? Much much thanks in advance....
How do i swap mileage?
Okay, I went ahead and installed the SE speedometer, however, is there a way to swap the mileage so it is correct? The new se speedo is almost double what mine is....any help would be appreciated!
The I30 cluster will plug right in, but it won't operate.
I did an I35 cluster swap on my 2002 max, and it was a lot of work. Well worth it to me, but I also chose to mod the cluster to work on a maxima rather than mod the cars wiring. That way I can always go back to my stock cluster, and if I ever decided to sell the I35 cluster...it'd be direct plug & play for the new owner.
REDinLV
08-15-2024 12:30 AM
dvcamp
09-18-2015 10:17 AM
