oil light
Old Apr 29, 2013 | 10:10 AM
  #41
SexyChics'03Max's Avatar
Originally Posted by chrome91
oil light for a second on startup is normal, just oil pressure building up. its low for that initial second
noise cold be anything, could be timing chain noise, lifter noise, etc. first thing you need to figure out is if its from the bottom or top end
I agree. Mine does the flickering oil light. Thats normal.
Old Apr 29, 2013 | 05:47 PM
  #42
chrome91's Avatar
Originally Posted by cmd26
I cant do anything about my pre cat to expensive right now. I was told my coolant leak is from a hose going into the oil filter im guessing he meant the oil cooler, do I need to drain the coolant out to replace these hoses I discovered there are 2 hoses one on either side of the oil cooler.
where exactly is it leaking? ATF will leak by the rad oil cooler lines, but coolant around that area is probably the rad itself leaking or one of the rad hoses. ATF and coolant get their own chambers in the radiator area, so coolant shouldnt be coming near the oil cooler lines
Old Apr 29, 2013 | 08:43 PM
  #43
cmd26's Avatar
The shop said its a metal hose that leads from the rad to the oil cooler he said its rotted out. Its def coolant I can smell sometimes.
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
sdotcarter
Sep 2, 2015 09:53 PM
