2001 Maxima will not start
Old Mar 7, 2013 | 12:16 AM
andreald's Avatar
I was driving when my car suddenly without warning shut off. Managed to get my car to a safe spot while coasting. Initially thought it may have been a battery issue, but when the key is turned to aux, everything turns on. Tried a jump start anyways with no avail.
When turning on the car, it will crank, but it will not start. The starter was replaced less than a month ago. The noise starting up is completely different than when my starter had gone previously. The noise itself on start up sounds horrible. No check engine light, no previous warnings.
Old Mar 7, 2013 | 02:59 PM
01maxium's Avatar
This happened to me two weeks ago. I just added water in the battery and drove around for a while for it to mix with battery acid. Just pop the caps off on the battery and add water.
Old Mar 7, 2013 | 03:23 PM
Bossmanreuben's Avatar
Could it be the fuel pump?
Old Mar 7, 2013 | 03:28 PM
jandk's Avatar
^ am guessing the same thing..fuel pump might be bad..or u may just ran out of gas without knowing...
Old Mar 7, 2013 | 03:41 PM
JWatZ's Avatar
Same exact thing happened to my Excursion back in September. Had the battery and alternator tested, they were fine. Replaced fuel filter, nothing. Replaced fuses and relays for fuel pump, nothing. $700 later I had a local shop replace the fuel pump. Did I mention I filled the 44 gallon tank before it went?
Old Mar 7, 2013 | 03:52 PM
noahrexion's Avatar
Fuel pump, make sure you get oem.
Old Mar 7, 2013 | 04:17 PM
SuperStasiu's Avatar
hook it up to a scan tool could be a camshaft position sensor, happened to me like that also. Car would crank all you want but wouldnt turn over, there was no check engine or no service engine light. I replaced the fuel pump and filter still nothing, decided to hook up a scan tool and BAM camshaft position sensor.
Old Mar 7, 2013 | 04:18 PM
lol wtf btw your suppose to use distilled water to do this
Old Mar 7, 2013 | 04:57 PM
jandk's Avatar
try turning it over while pumping on the gas paddle...
ah2002
Mar 9, 2016 01:42 PM
District
Aug 15, 2015 08:23 PM
kirkhilles
Aug 8, 2015 10:53 AM
dauntlessmax
Aug 5, 2015 10:29 AM
wpr
Aug 5, 2015 03:28 AM
