upper pan install question
Old Mar 22, 2013 | 10:26 AM
uptownsamcv's Avatar
ill be installing my pan tomorow and was wondring if its ok to use a lil RTV to stick the o-rings to the oil pump and block so they dont fall off during install ???
Old Mar 22, 2013 | 03:26 PM
rebelhell's Avatar
I used a dab of vaseline on each of them and didn't have any problems. I don't think RTV is a good idea.
Also another tip: Buy some long bolts with the same thread as the upper pan bolts. Grind the heads off and cut a slot in the end of each with a Dremel so you basically have two long screws without a head. Screw one into each side of the block and use them to guide the pan straight into place so you don't smear your RTV bead around. Once you have a few bolts tightened to hold the pan in place you can back out the screw/studs you made with a straight slot screwdriver and then continue to bolt up and torque the pan in place. Worked great for me.
Old Mar 26, 2013 | 10:44 AM
do I need to apply any RTV on the 2 end gaskets ?
Old Mar 26, 2013 | 05:13 PM
rebelhell's Avatar
Yes, the FSM shows RTV on the ends of the half moon gaskets. I put RTV across their entire length with no ill effect.
PH98I30
Jan 9, 2025 08:08 AM
Matt93SE
Apr 8, 2018 09:23 AM
iflexsteel
Sep 15, 2015 03:37 AM
Team STILLEN
Aug 10, 2015 04:29 PM
