Maintenance @ 250,000 miles
Old Apr 15, 2013 | 09:39 AM
Max Nu-BE's Avatar
Whats up guys, just want to ask your opinion on what should be maintained on my car at 205,000 miles. Any suggestions?
Old Apr 15, 2013 | 09:48 AM
maxima_tyler's Avatar
tranny fluid
brake fluid
oil
all filters
all belts
check shocks and brakes, other suspension components for wear and tear
spark plugs
really, just check anything and everything for wear and tear. if the condition is bad, replace the parts.
Old Apr 15, 2013 | 10:11 AM
vq30nismo's Avatar
^ Agreed.
There's no set check list for that amount of miles other then given it a really good look over.
I would change out the brake fluid and power steering fluid since those never get much attention and do have a service life.
If there's any leaks oil / transmission i would get those fixed and also change the transmission fluid depending on color and smell of it.
Other then that i would take a good look at the suspension since the rubber bushing in the control arms in the front along with the bushing in the back axle might have gone bad by now.
If it's the stock motor i would listen to make sure the timing chain isn't making any noise from worn down guides. If they are i would get that look at if not then good to go.
Old Apr 15, 2013 | 02:42 PM
tcb_02_max's Avatar
205k or 250k? Just pointing out you have a discrepancy between your title and the post...
03VQMAX
Nov 10, 2015 03:39 PM
pears
Sep 18, 2015 05:25 AM
Jay556
Sep 12, 2015 05:50 PM
crazyespn
Sep 3, 2015 01:30 PM
