Worth doing these re-learns?
Old Apr 17, 2013 | 09:03 PM
mclasser's Avatar
I cleaned out my MAF a few months back and put in a new battery shortly after. Forgive me if I sound like an amateur, but should the new battery installation have reset the ECU? Would doing the accelerator position, throttle valve closed pos. and idle air re-learns (in this order) be a good way to 'refresh' the system on an 11 yr-old car? I know these procedures should typically never be required but I am just curious about them.
Old Apr 17, 2013 | 11:54 PM
slo-ryde's Avatar
Not sure if it's worth the trouble. I just spent a day working on my car with the battery disconnected the entire time. When done I reconnected the battery and fired up the car with no issues. Some think the cars get amnesia after the battery is disconnected, I've never seen any evidence to support it.
FWIW: Nissan does not recommend cleaning the MAF, my '02 has 240K on it and it has never been cleaned. I've looked at it a few times over the years but see nothing on it.
Old Apr 18, 2013 | 06:57 AM
NmexMAX's Avatar
dot dot dot ...
I wouldn't, but it's a good time to get some practice at it.
Old Apr 18, 2013 | 09:41 AM
cjandura's Avatar
Dont cypher do this?
Old Apr 18, 2013 | 10:33 AM
rebelhell's Avatar
Technically, the manual says you only have to do a throttle or IAC relearn if they or the ECU is disconnected. It says nothing about the battery. I've had my battery disconnected multiple times without issue. But as soon as I disconnected my IAC valve I popped a code requiring a relearn. Not sure why this is the case.
Old Apr 18, 2013 | 11:04 AM
slo-ryde's Avatar
Did you disconnect the IACV with the battery still connected? I owned a BMW for a short while and found out unplugging the harnesses under the seat ( I was removing the front seats to clean up a nasty soft drink spill) with the battery connected would set the airbag light. It took a trip to the shop to get the airbag light reset. Maybe the IACV behaves the same way?
Old Apr 18, 2013 | 11:11 AM
rebelhell's Avatar
Originally Posted by slo-ryde
Did you disconnect the IACV with the battery still connected? I owned a BMW for a short while and found out unplugging the harnesses under the seat ( I was removing the front seats to clean up a nasty soft drink spill) set the airbag light. It took a trip to the shop to get the airbag light reset. Maybe the IACV behaves the same way?
Nooo, I had the battery out. Was pulling the intake manifold to install spacers and to replace the rear valve cover. I always disconnect the battery first. But I had the battery disconnected several times while installing my Nav and never had to do the relearn after that.
Old Apr 18, 2013 | 11:15 AM
Crusher103's Avatar
No man, Cypher is a term for a bunch of rappers freestyling over a dope beat.
Old Apr 18, 2013 | 11:16 AM
cjandura's Avatar
Hood Rat
Crusher103's Avatar
Rats be in da hood.
Old Apr 18, 2013 | 08:05 PM
Anovice's Avatar
I have a 2000 I-30 and had the IAC valve changed yesterday because of a code PO505. The battery was removed first and then the IACV changed. The mechanic started the car up, the "Check Engine soon" light went off, no re-learn, no more erratic idle, and the car purrs at 700 RPM.
And, the ECU was not fried as some on the boards said would be the case.
Anovice
Old Apr 19, 2013 | 06:57 AM
NmexMAX's Avatar
dot dot dot ...
that too.
Cipher ftw
I've had my share of pedal dances though.
Forge277
Jun 13, 2016 09:26 PM
lrb6805
Sep 30, 2015 08:12 AM
homewrecker
Sep 24, 2015 07:01 PM
Dasmith
Sep 23, 2015 08:28 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
