Engine issue?
Engine issue?
A few days ago I noticed that the oil light flickered for a second after startup. Normally it doesn't do that. Today, it started blinking a little longer at startup and I can hear the engine running louder than it usually does. I checked the oil level and it is right where it should be, and the oil is still fresh (Mobil 1 EP 10w-30) I changed it last month. The only problem in the engine bay I can observe is there is a slight hissing sound in the back. Is this normal? I checked all the hoses and they seem fine. No CEL.
<iframe width="560" height="315" src="
" frameborder="0" allowfullscreen></iframe>
Engine sounds fine, change the oil pressure sensor and see if the problem with the light continues. The Hissssssssssss is most likely a vacuum leak, Check Engine light on?
MAXSE5SPD
Sep 17, 2022 04:00 AM
Maxima30
Sep 7, 2015 06:13 PM
