5th Gen: What did you do to your 5th Gen today?
Jul 13, 2014 | 07:59 PM
  #961
^That looks like a sway bar bushing.
Jul 13, 2014 | 08:06 PM
  #962
It does.
Mine is there so.... idk.
Maybe somebody is playing a trick on me.
Jul 13, 2014 | 08:55 PM
  #963
Ok so installed the axle,the tick noise went away but a screech grinding noise remains, I'm sure is the bearing
No issues ,two hr job in the baking Texas heat'
Lots if water breaks and also changed the ps suction hose.
If it leaks fluid after this it has to be the pump,i hope not
Jul 14, 2014 | 02:53 PM
  #964
changed my camshaft sensors bank1 and bank 2 took me about 1 hour next is the crankshaft sensor
Jul 14, 2014 | 08:40 PM
  #965
New Bank 2 Downstream O2 sensor to fix my p0138 and all new mounts for the engine and one for the tranny. Way to much work but should be worth it
Jul 15, 2014 | 09:29 AM
  #966
Changed out fuel filter...was a whole lot easier than I anticipated. Hope this helps with my poor fuel economy but we'll see. Last time I check was around 17mpg city/22mpg hwy
Jul 15, 2014 | 03:24 PM
  #967
Passenger and driver lower control arms and bushings, both outer tie rods, and both sway bar links on my I35. Feels like a new car lol
Jul 15, 2014 | 04:10 PM
  #968
Quote: Changed out fuel filter...was a whole lot easier than I anticipated. Hope this helps with my poor fuel economy but we'll see. Last time I check was around 17mpg city/22mpg hwy
Cut it open. Lets see what it looks like
Jul 15, 2014 | 07:39 PM
  #969
Quote: Cut it open. Lets see what it looks like
Yeah it was pretty dark in there, so much for it not ever needing to be serviced
Jul 15, 2014 | 07:50 PM
  #970
Back ordered AE door sills finally came in...just as I was about to cancel order and buy those illuminated ones:
Jul 16, 2014 | 07:29 PM
  #971
Replaced my A/C condenser today. In 85 degree heat. Without removing the radiator from the car. Had some problems with the hardline on the driver side. Got the connection as tight as I could, but the line of the condenser was starting to rotate. The metal in these things are quite malleable, so I'm kinda worried I might have damaged it. The litmus test will be Friday when I get the A/C recharged.
Jul 17, 2014 | 08:19 PM
  #972
Well, I decided to charge the A/C system myself. Saved almost $100 doing it. Starting off I did find a leak on the high pressure line between the compressor and the condenser. Retighten and fixed it up. So far no leaks, A/C is icy cold. Even the low pressure line is getting frosty which is it did before I had problems. Now to monitor for a couple days and see where we're at.
S
Jul 17, 2014 | 10:53 PM
  #973
^ nice i need to recharge mine as well.
I installed my old "spare" indash in the maxima today. Not too happy with metra kit fitment. It has a small gap below the bezel/above climate control. This seems to vary as i tighten/loosen screws holding deck in.
Im gonna go back at it when time allows to finish a few more wires for subs/amp.
Jul 18, 2014 | 05:31 AM
  #974
Quote: Yeah it was pretty dark in there, so much for it not ever needing to be serviced
When they made the car and said "not serviceble" for the fuel filter, they didn't anticipate our fuels having 10+% of ethanol. Shame really, a real shame.
Jul 18, 2014 | 09:56 AM
  #975
Inspected my grounds, found one with corrosion !
Jul 18, 2014 | 09:51 PM
  #976
Bought a steamer and
deep cleaned my leather.
uses lexol conditioner.
Got in all the cracks and seat rails.
Got all the nasty crap out.
Feeling clean clean clean.
Jul 18, 2014 | 10:43 PM
  #977
Deleted edit.....
Jul 18, 2014 | 11:45 PM
  #978
lexol
Lexol is the best stuff iv ever used on leather.: Smells strong in car for few days but leaves leather clean/supple!
Jul 20, 2014 | 12:55 AM
  #979
^I don't like it because it's sticky like honey after it dries and
you have to buff it out with a towel to get it smooth.
Don't know if that's normal for a conditioner.
I'm used to more liquidity stuff that's easy to wipe off like armerall or miguers stuff.
Check out all that grime in the cracks.
That shiny stuff on the leather is actually my butt juices and body oils. lol
Steamed, before conditioning.
Took off all the grime and oils.
Don't think a cleaner would of done that good of a job.
Jul 20, 2014 | 07:26 AM
  #980
What steam cleaner did you use?
Jul 20, 2014 | 11:01 AM
  #981
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Jul 20, 2014 | 01:13 PM
  #982
Thanks mang!
Jul 20, 2014 | 02:11 PM
  #983
I fabricated my own axel back 3" exhaust. Thats what I did with my 5.5 gen today. I bought a Carltanator a few months back which only is the resonator no pipping. So with cattman out of no longer making parts and the fact that all of the exhaust parts that are nice are enormously overpriced I ordered pipping and a muffler and made one myself. I can weld, have a brain, and mechanical ability so why not. It wasn't too difficult and it still needs a tweak or two but I'm extremely happy with it. Ad to that the fact that it cost me fractions of the price and I'm even more happy.
Jul 20, 2014 | 04:34 PM
  #984
Today i parked my maxima in garage for the first time. Ever since we bought the house...its been a long slow process organizing belongings.
Accomplishments Once inside; I rewired my fogs/Installed leds in doors, lisc plate, reverse lights (festoons are coming for domes)/ Finished installing a dual din.
Next up is Focal Speakers in door sitting and waiting/Compass rearview/change all door handles to oem chrome accent gle style/racingline fstb/GAB re-do/plus a long list..mostly visual mods for now.
__________________________________________________ _______
Lets see some pics of it. Im sure its doable with patience in hand.
Quote: I fabricated my own axel back 3" exhaust. Thats what I did with my 5.5 gen today. I bought a Carltanator a few months back which only is the resonator no pipping. So with cattman out of no longer making parts and the fact that all of the exhaust parts that are nice are enormously overpriced I ordered pipping and a muffler and made one myself. I can weld, have a brain, and mechanical ability so why not. It wasn't too difficult and it still needs a tweak or two but I'm extremely happy with it. Ad to that the fact that it cost me fractions of the price and I'm even more happy.
Jul 20, 2014 | 08:18 PM
  #985
Just a short drive. Even got a driving award.
https://i.imgur.com/Nmw6R5M
Jul 21, 2014 | 06:05 AM
  #986
Nice driving award, 290,000k miles is quite an accomplishment. Subtract about 200k and that's where my Max is at, guess I still have a LOOONG way to go with my Max.
Jul 21, 2014 | 07:06 AM
  #987
Recently removed dip from my entire car so i'm back to Merlot...that was a pain in the a$$. I put on window visors which I found out are apparently illegal in CA...wtf??? Really??? Oh well i'm already a law breaker since I "modified" my vehicle by lowering it and tinting my windows what's one more? lol
Jul 21, 2014 | 09:30 AM
  #988
Quote: Today i parked my maxima in garage for the first time. Ever since we bought the house...its been a long slow process organizing belongings.
I'm still not 100% done with it but when I get all the bugs worked out I will post pictures for sure.
Sent from my iPhone using MaximaOrg
Jul 21, 2014 | 09:35 AM
  #989
It's very doable. Patience is a must and I'm not going to claim its as pretty as a cattman system. It sounds great and I have probably $140 maybe a little less into it.
Jul 21, 2014 | 10:01 AM
  #990
Cleaned it up and did an alignment.
Jul 21, 2014 | 02:03 PM
  #991
She is all cleaned up and wax and she needs to be lower moar!!
2001 Maxima SE
Jul 21, 2014 | 02:51 PM
  #992
Very nice! You know what would awesome is some pictures. I've been considering doing this myself. I'm only missing a welder, a saw and whatever else I need. Oh and and a clue.
Jul 21, 2014 | 03:06 PM
  #993
Quote: Nice driving award, 290,000k miles is quite an accomplishment. Subtract about 200k and that's where my Max is at, guess I still have a LOOONG way to go with my Max.
Haha thank you. I tried to use CB slang. http://en.m.wikipedia.org/wiki/List_of_CB_slang
Got Bit By A Bear"
Received A Ticket.
Jul 21, 2014 | 04:21 PM
  #994
Quote: Cleaned it up and did an alignment.
Take a picture of alinement sheet please just out of curiosity.
Jul 21, 2014 | 06:58 PM
  #995
The Max as of recent
So recently, i've been busy with the max I broke 60,000 miles. Debadged the trunk, replaced my headlights/fog lights with nokya yellow h3 builbs. I plasti dipped my front rims, i'm too lazy to remove the rears until they get rotated, eventually, oh and i did led license plate lights. I'm new here but i drive Merlot Se 4at
Jul 21, 2014 | 07:49 PM
  #996
I plan on posting pictures as soon as its 100% done and I'm satisfied with it. I would use torches an braze the pieces. A cutting wheel or your preferred method is a must. Doing it again I could make it much more pleasing to the eye. If you're close to jersey I can help you if you would like to try.
Jul 21, 2014 | 08:07 PM
  #997
Quote: Did a pan drop and tranny flush.
If you want amsoil stuff talkinghorse will get you a good price. http://forums.maxima.org/group-deals...ubricants.html
Anyway. Used a sweet inline filter after the cooler. Should be good for some years.
Are these metal shavings attached to your magnets ?? How much gunk was there, and what's the mileage on the car?
I guess I should also drop the pan .... Also, where did you buy the filter?
Jul 21, 2014 | 09:07 PM
  #998
Filter from amazon. It's paper filter plus a magnet.
Yes, that's basically a metal paste on the magnets. Almost 200,000 miles.
Jul 22, 2014 | 08:37 AM
  #999
getting an alignment
Jul 22, 2014 | 03:06 PM
  #1000
I lowered her and replaced the right rear caliber
