5th Gen: What did you do to your 5th Gen today?
Old Jul 4, 2015 | 03:06 AM
  #2161
tosheto's Avatar
Vacuumed it, adjusted the tire pressure, and serviced the A/C.
Old Jul 4, 2015 | 07:44 AM
  #2162
cornholio's Avatar
Originally Posted by a33_ridah
^You'll be set for a longgg while with a new one. Replacing both upper and lower rad hoses as well for peace of mind??
& that rad support seems to be pretty far gone.
Hoses looked in decent shape so I decided not to replace them. Not sure that I want to deal with fixing that rad support so there might be some tough decisions to make in the future.
Old Jul 4, 2015 | 09:18 AM
  #2163
a33_ridah's Avatar
^Advisable to replace em still. Are you planning on leaving the 5th gen fold if you dont fix the rad support? is that what it would come down to. Theres many diy fixes of it on here iv seen over the years- ranging in complexity.
Old Jul 4, 2015 | 09:58 AM
  #2164
cornholio's Avatar
Not sure what I would do, if the car gets replaced it'll be with something cheap. It's not a daily vehicle so no need to spend a bunch of money on something that just depreciates while sitting in a parking garage 90% of the time. Another 5th gen is tempting as I'm now familiar with them and have been through a lot of the common issues. On the other hand I do know the full history of my current one so maybe just keep it and do the repairs. Idk it's a tough call, will have to put some thought into it.
Old Jul 4, 2015 | 12:36 PM
  #2165
WTF?'s Avatar
Making subframe connectors today....or more likely, cutting up some scrap 1x2 tubing, and messing around.
Old Jul 6, 2015 | 10:18 AM
  #2166
D.Stillwell's Avatar
Wash, Clay bar, polish, hand glaze, Stage III wax....all done by the master detailer himself
Shout out to lux97max for getting this done right!
Old Jul 6, 2015 | 04:45 PM
  #2167
02PearlSE's Avatar
Bought an 02 SE 6spd to replace my mustang, and am in love
Old Jul 6, 2015 | 04:53 PM
  #2168
95VQ30's Avatar
looks very good- love the wheels
Old Jul 9, 2015 | 10:59 PM
  #2169
Donkeypunch's Avatar
Replaced the dead unit with a borg warner.
Job was probably 2/10. The tough part is getting the screws lose if you don't
have the right tools. They shouldn't come off using a normal screwdriver and hand strength alone.
Old Jul 12, 2015 | 06:21 PM
  #2170
driscoll_jason@ymail.com's Avatar
Just a grill and big brakes
Drivers side rear orange epoxy
front with 2006 caliper
Badge delete
grill and hella horns
paint is thick and easy to clean
shouldn't have painted badge orange
Old Jul 12, 2015 | 07:07 PM
  #2171
losifanatic's Avatar
Washed, waxed, and cleaned the inside of both my 03s. Also changed the plugs and coil packs in my silver one. Will be installing new kyb struts and h&r springs tomorrow.
Attached Thumbnails 5th Gen: What did you do to your 5th Gen today?-20150711_163226.jpg   5th Gen: What did you do to your 5th Gen today?-20150711_163259.jpg   5th Gen: What did you do to your 5th Gen today?-20150712_111355.jpg   5th Gen: What did you do to your 5th Gen today?-20150712_111320.jpg   5th Gen: What did you do to your 5th Gen today?-2015-07-12-22.02.37.jpg
Old Jul 12, 2015 | 08:14 PM
  #2172
doombot's Avatar
Installed KYB AGX shocks and Eibach springs, which turned out to be a huge pain in the ***.
Old Jul 12, 2015 | 08:39 PM
  #2173
losifanatic, how old are those plugs?
copper?
Old Jul 12, 2015 | 10:43 PM
  #2174
Atemus_Prime's Avatar
Finally put her back together after a week
My fault on the potato-taken picture, had to get a quick one.
Went ahead and did a few engine components:
NWP Intake Spacers
Valve cover gaskets + tube seals
OEM COILS so no more p1320
NGK Iridium
PCV
Breather hose
IACV
Shinjiduo Grounding kit + Big 3
New Injectors
Cleaned EGR
Runs like a whole new car
Old Jul 13, 2015 | 06:21 AM
  #2175
copper?
They are platinum. I'm guessing they are the factory ones. I just bought the car. It has 101,000 miles on it. Been cleaning the mess out of it. The previous owner apparently wasn't about keeping a car clean. I also have new rotors and pads coming. Should be here by the end of the week.
I replaced the struts on my other 03 and my 2k. It's not to terribly bad. I have an impact wrench and a spring compressor which makes it much easier than when I had to do it by hand with a ratchet strap to compress the spring like I did years ago on the 2k. Won't do it like that again!
Old Jul 13, 2015 | 10:38 PM
  #2176
Jprocs24's Avatar
My Max got dusty and I killed a few mosquito's by hitting them... So I gave it a good wash/ detail!
Old Jul 14, 2015 | 03:59 PM
  #2177
Hope this helps people out.
My idle control valve died about a week ago throwing codes.
After replacing it there where just:
p0135
p0141
p0155
p0161
These are all heater circuit malfunctions from the o2 sensor.
All 4 of them. Very suspicious.
Turns out the fuse blew for engine control.
Somehow when the idle control valve blew it blew my o2 sensor fuse.
strange.
All good now.
Old Jul 15, 2015 | 11:06 AM
  #2178
Heel Til I Die's Avatar
Had the all-too-familiar SES light come on about a couple weeks ago. Pulled the codes. Only the dreaded 1320 came up. I took her wide open a few times to see if it would trigger the misfire cylinder number. No luck and zero hesitation or misfire symptoms. It still ran perfect.
Today, I got to fill up with some premium fuel with 0% ethanol. Drove about 100 miles. Started the car after it had been off for a few hours.
Poof! No more SES light!
I didn't really feel like breaking out the multimeter anyway...
Old Jul 15, 2015 | 11:26 AM
  #2179
Kevin Trout's Avatar
A few days ago I decided to change my cabin air filter, and look over my exhaust system for leaks. I found that the gasket between my test pipe and resonator had completely blown out, thankfully I had a new oem gasket on hand to replace it with. Now my header/exhaust combo is much quieter, and I don't have so much of the horrible smelling exhaust (no cats anymore) infiltrating my interior.
I also decided to clean my AEM dryflow filter, although it really wasn't terribly dirty. On the first time I took it for a drive the next day I suddenly had issues with stalling (deactivating my sprint booster fixed this issue), hesitation above 3500RPM, and an inconsistent idle. When I parked at the mall I disconnnected and reconnected the harness clip for the MAF sensor, and thankfully this fixed the issues. I must have had a poor connection, I will clean the harness connector with some contact cleaner. I also plan to clean the MAF as well, I used to run oiled K&N filters for many years, so perhaps a cleaning is in order.
Old Jul 15, 2015 | 11:40 AM
  #2180
NmexMAX's Avatar
dot dot dot ...
Had some blonde moments recently adding some brakes to the car.
Installed FB rear BBK, got caught up and didn't have dual jack stand ( I do now, not a week ago though), so I put the front wheels back on and raised the rear, got caught up, and couldn't even get a hard pedal with the car off, 2 liters of brake fluid, and bam, SOB, forgot the passenger side caliper crush gaskets. Awesome, got a firm pedal with the car off, oh snap, bled again. Hmm WTMF is wrong with me? Only bled one side/nipple of the calipers, pedal spongy as all m'fkn hell when on (brake booster working). So yeah, headed home today to bleed again.
3 sets of speed bleeders, 1 vacuum bleeder tool, and 1 (awesome by the way) caliper piston tool later and I think I'm on my way, although the rear brakes began making the infamous FB Rear BBK grinding noise out back, need to take a look at that.
Oh yeah, and I think my steel oil pan is leaking or I know it is. Don't think it's the cooler o-ring, although I bought one just in case. I will change that and keep an eye on it. If that's not it, I'll change the oil pan RTV. I might even use a gasket even though it stated not to, heard good things of the Fel-Pro unit. After all, don't want to add Amsoil that I have ready to go in if I just have to drain it all out again.
Fun fun fun, too old for this sh^t.
Oh yeah and my commuter's PS took a poo, 800$ to replace PS lines, sold that. Pathfinder needs some sort of pulley bearing, not sure which one it is at this point but I've been driving that beast to work, 100 miles a day @ 12.5 MPG, not cool. Not to mention wearing my 400$ 35" tires. Yeah I hope I solve this brake issue soon.
Old Jul 16, 2015 | 08:44 PM
  #2181
DennisMik's Avatar
I finally installed my Kenwood head unit to replace the Bose. I ordered the Kenwood about 6 weeks ago, but this was a case of nothing going right on what should be a simple job. The most aggravating part was the Metra antenna adapter. I ordered it from some schmuk named Alex Razipour that sells on Amazon under the name of Car Audio Online. He is in Los Angles and ships the stuff through a UPS store.
He originally shipped me the wrong thing and then became non-communicative. Back on June 29th, he sends an e-mail saying he is shipping me a replacement. A week and a half later I don't have it. I send him another email saying that I better have either the part or my money back by July 10th. No response, nothing by July 10th. July 11th I called my credit card company and got them to reverse the payment and credit my card back. I also ordered another antenna adapter from somewhere else.
So Monday I get an email from this guy saying he is shipping me a replacement part and gives me a post office tracking number. Tuesday afternoon when I enter the tracking number into the postal web site, it comes back as invalid. Oh well. I don't care anymore. I got the other adapter I ordered an the radio is installed. I wonder what good old Alex will do when he finds out that the credit card company took the money back.
Old Jul 20, 2015 | 09:38 AM
  #2182
TheMafia's Avatar
Went to the wreckers this weekend hoping to get everything on my list......went better than expected...
in the part of the lot where they just received new cars from auctions, was a mint maxima there with my name on it, got all the parts i needed:
complete center console
fuel cover release motor(or mechanism)
battery strap/bracket
installing all of them later today!
Old Jul 20, 2015 | 11:50 AM
  #2183
Got my struts and lowering springs installed, tie rod ends installed, and new drilled rotors and ceramic brake pads installed. Now to install a new DVD player next week.
Old Jul 20, 2015 | 11:58 AM
  #2184
TheMafia's Avatar
what brand/model of dvd player?
what face plate? (thing that surrounds the dvd)
Old Jul 20, 2015 | 01:06 PM
  #2185
Pioneer avh-x2700bs. Just some bs Metra double din plate for now. Going to order the factory double din opening like I did for my 2000. Just wish they made it the right color for a 2003. Oh well the darker gray will probably look better with the black interior
Old Jul 20, 2015 | 10:42 PM
  #2186
Is there a "what stereo do you have" thread for 5 gen?
Old Jul 21, 2015 | 07:08 AM
  #2187
TheMafia's Avatar
Scosche NN1648B 2000-03 Nissan Maxima Double DIN or DIN w/pocket Install Dash Kit
people on the forum recommended this, it seems to be a match or at least fairly close??
http://www.scosche.com/car-audio/200...nd-dbl-din-kit
Old Jul 21, 2015 | 07:17 AM
  #2188
TheMafia's Avatar
installs done!! also pinned the trunk lining in as it was all over the place.
the fuel cover release works great but the metal piece that acted as a spring was not pushing enough to open the cover when i pressed the button, adjusted that now it pops open.
unfortunately i found out that the driver side seat heater light isnt coming on on this console as well (last was the same, but the buttons are new now) so it must have issue else where. any suggestions help
Old Jul 24, 2015 | 09:12 PM
  #2189
DennisMik's Avatar
Can you tell if the seat heats up? I assume the heater worked with the old console, so I would think that the switch is bad. If the seat heater is working, then it is just the light that burned out. If the seat heater doesn't work, then the whole switch is bad.
Either way, swap out the switch with one from the old console. Both seats use the same switch.
Old Jul 25, 2015 | 05:58 AM
  #2190
Well getting new toyo tires installed and an alignment. My car is finally ready to be driven.
Ordered the factory double din/vent. I know it's a different color so I'm going to order an ac control off eday to match. I just don't like the look of the Metra D-Din. Looks cheap.
Old Jul 25, 2015 | 08:35 AM
  #2191
Cotozic's Avatar
I've had the Metra and the Scosche double dins and they feel just as cheap as the OEM. What I thought was a bit ironic is that while the OEM double din has the trim detail to match the HVAC controls, the trim is not defined the the extent that the HVAC controls has. It's a subtle difference, and it's just kinda weird. It's like that of comparing a blurry picture to a clear picture. Don't get me wrong though, the OEM double din looks the best.
Old Jul 25, 2015 | 10:01 AM
  #2192
Yeah I have the oem one in my 2000.
Also going to the tire place I found I have a small crack in my radiator. Dang this car has cost me a fortune and I just bought it
Old Jul 25, 2015 | 10:33 AM
  #2193
Jprocs24's Avatar
They aren't cheap, that's for sure.
Old Jul 25, 2015 | 12:19 PM
  #2194
Just put a bid on a dark gray ac controller. Cleaned both the 2003s and have one waxed and taking a break before I wax the other.
Old Jul 25, 2015 | 01:27 PM
  #2195
doombot's Avatar
New rear calipers, rear Hawk HPS brake pads, and rear Brembo rotors. Also had a new driver's side control arm installed.
Old Jul 25, 2015 | 02:58 PM
  #2196
DennisMik's Avatar
Went to start the car yesterday and had smoke and flames, so I had to replace my alternator and the wires going to it.
When I got under the car, I saw that the right CV axle was flinging grease all over the place. So I have another project.
Old Jul 25, 2015 | 03:09 PM
  #2197
nestorlugo's Avatar
:dang!!!! Rip to the alt.
I feel your pain on the axle i replaced my passenger side axle two weeks ago with a reman from the parts store and it's doing the same....smh i think i'll just replace the Japanese style clamp they use for a worm(American) style clamp to fix it!
Old Jul 25, 2015 | 04:28 PM
  #2198
george__'s Avatar
the things you do for your car
Old Jul 25, 2015 | 06:08 PM
  #2199
DennisMik's Avatar
Unlike most of the people that own cars, I don't have any attachment to it. It is like a ball point pen to me - when it can't do its job anymore, it is history.
I look at what the problem is and if I consider it to be normal stuff, I don't get upset over that. I don't know if this car can sense it, but it has been pretty good to me.
Old Jul 25, 2015 | 09:55 PM
  #2200
Qlampkin's Avatar
Bought some leather back seats for 35 dollars and got the silver kick plates for free. Got to clean them. And might go get the heated black leather seats out of a 6th gen tomar if I can talk dude into giving me a good price.
