5th Gen: What did you do to your 5th Gen today?
Old Jul 15, 2016 | 04:01 PM
  #2681
nestorlugo's Avatar
Originally Posted by Itz Shak
So I went to a junkyard today to swap out clusters.. I plug in the one from the junkyard and it was worse than my original.
It's stuck @ Full tank and has 228k miles on it.
They don't do refunds on electrical parts, so they're going to find me another one by Monday.
Ask if you can swap it for a sending unit!
Old Jul 15, 2016 | 11:19 PM
  #2682
Itz Shak's Avatar
I was thinking this aswell. If this gauge cluster doesn't work, that's next.
Old Jul 16, 2016 | 07:02 PM
  #2683
cornholio's Avatar
maintenance stuff - oil change, trans drain/fill
then replaced crankshaft seal hoping to stop an oil leak
somethings leaking in here:
halfass cleanup with new seal:
will have to see if that takes care of it or not
also pried the front passenger rotor shield back some, has seemed to take care of my mystery noise. happy that it was a simple fix
Old Jul 16, 2016 | 07:55 PM
  #2684
Itz Shak's Avatar
Could the leak be the oil cooler o ring?
Good job on maintenance.
Old Jul 16, 2016 | 08:35 PM
  #2685
cornholio's Avatar
maybe, but i don't think the vq30 has an oil cooler kinda learning as i go here
i am pretty sure i have a leak from the rear main seal as well, since i am finding oil under the engine/trans connection. this leak will probably go on forever, since i don't think i'll tear this bish down enough to fix it.
Old Jul 16, 2016 | 11:12 PM
  #2686
Itz Shak's Avatar
Oh, thought you had a 3.5. Hopefully you sealed it already
Old Jul 17, 2016 | 12:48 AM
  #2687
Child_uv_KoRn's Avatar
Bad *** Newb
AT-205 stop leak. Good chance it'll stop it if it's not big leak. You're right, it's not worth the trouble of pulling the oil pan to fix it.
Old Jul 17, 2016 | 08:30 AM
  #2688
george__'s Avatar
Had to work today *BOO* so I took the Maxima instead of my other DD to the office today.
Old Jul 17, 2016 | 06:42 PM
  #2689
HerBlue2kSE's Avatar
Enjoyed the new look
Please forgive the dirty car that has been in the garage for two months now.
Attached Thumbnails 5th Gen: What did you do to your 5th Gen today?-image.jpeg
Old Jul 20, 2016 | 08:37 AM
  #2690
Itz Shak's Avatar
Just received this thang @ the front door.
Excited!! Even though I don't necessarily know how to use it yet
Old Jul 20, 2016 | 10:22 AM
  #2691
losifanatic's Avatar
NICE.
I picked up the vafc2(6 months ago). Haven't installed it yet. I need to get a wide band first
Old Jul 20, 2016 | 10:31 AM
  #2692
Itz Shak's Avatar
Originally Posted by losifanatic
NICE.
Same here, I've got the wideband coming soon. Just need to get the sensor now
Old Jul 20, 2016 | 09:37 PM
  #2693
Donkeypunch's Avatar
I resealed mine last year. ALL seals were leaking.
After everything was leak free it still was getting dirty in that area.
Turned out the water pump was weeping and it was dripping onto the pulley area.
Now my p/s line is leaking, but it feels good to have a completely perfectly running leak free 3.0.
I feel these things will last forever. Leak down was perfect.
Old Jul 21, 2016 | 09:31 AM
  #2694
VQ35maxima=Beast's Avatar
New exhaust manifold gaskets, new exhaust flange gaskets all the way around. Front pads and rotors.
Old Jul 22, 2016 | 07:20 PM
  #2695
Wrapped up my stereo upgrade and took it for a drive after the suspension rebuild, alignment, and new tires.
Old Jul 24, 2016 | 04:48 PM
  #2696
ramriv777's Avatar
'03 SE TE. P1800 code. VIAS solenoid, but the solenoid was fine. It was the vacuum lines. Replaced them all ($3.00 worth of hose) and cleared codes. No more CEL!!
Also replaced fuel tank cap, cabin and engine air filters while I was at it.
Old Jul 24, 2016 | 08:34 PM
  #2697
Itz Shak's Avatar
I haven't replaced my cabin filter since I've got the car.. I'm just lazy if it isn't preventive maintenance or adds power..
Old Jul 24, 2016 | 10:39 PM
  #2698
SquidBeak's Avatar
Here's what I've done since May:
Oil Change (Mobil 1), Filter (Mobil 1, M1-105) Tire Rotation
JBL GX602 Front Speakers
O2 Sensor - H2S2 - Bosch
Trans Flush - Amsoil
Trans Filter Install - Magnefine
Power Steering Flush - Amsoil
Power Steering Filter Install - Magnefine
Oil Catch Can - Harbor Freight
Air Filter - Cheapo - Still planning on SRI soon
In Cabin MicroFilter -
Fuel Filter - OEM (Beck/Arnley looked like junk)
Rear Brakes - turned rotors, rebuilt calipers, new pads, (OEM - had a set already)
Drive Belts - Gates
ES Sway Bar Bushings
Moog Sway Bar Links
ES Front/Rear Engine Mounts
Control Arms w/ ES BUshings & Moog Ball joints
Moog Tie Rod Ends
4 KYB struts, 4 Febest Boots, 2 Moog Front Mounts
Alignment
Wrayth Passenger & Trans Poly Mounts
Items still on list:
Swap precats w/ gutted pre-cats
04 Rear valve Cover
SRI
ES Subframe bushings - maybe
Subframe washers - maybe
The car better run forever after all of this!
Old Jul 25, 2016 | 07:44 AM
  #2699
Itz Shak's Avatar
Drive Belts - Gates
Moog Sway Bar Links
Moog Tie Rod Ends
Alignment
04 Rear valve Cover
SRI
For sure
Old Jul 25, 2016 | 07:54 AM
  #2700
I hear that! Did similar repairs myself in the same timeframe:
- Rebuilt front suspension using ES poly bushings including motor mounts along with Knight's side mounts
- Moog front wheel bearings on both sides
- Moog sway bar end links
- Moog ball joints
- Moog inner and out tie rods
- Moog strut mounts
- KYB GR-2 struts and Febest boots
- picked up five 16" SE/GLE wheels and new Kumho Ecsta x4-II tires (one for full size matching spare)
Old Jul 25, 2016 | 06:04 PM
  #2701
SquidBeak's Avatar
- Moog ball joints
- Moog strut mounts
That's amazing. Almost exactly what I did!
Once I got in there, I almost regretted not replacing the inner tie rods, but I just didn't want to deal with the boots etc. It was a long enough day as it was with all the other parts. How was that particular job?
I'm loving the poly engine mounts!
I have to ask...how did you get your old control arm and engine mount bushings out? Did you have a press or did you take the hack saw approach?
Old Jul 25, 2016 | 09:48 PM
  #2702
I drilled holes in the rubber portions of both control arm and engine mount bushings, cut thru the metal portion of the bushing, and then peeled them back until I could beat them out with a 3lb hammer. Those control arm bushings made a real mess...
I pressed the bushings in at a friend's place with his input.
The inner tie rods were the source of much play on my car and I am glad I did the swap. I picked up the inner tie rod tool at Harbor Freight and it was pretty painless. The boots were worse than replacing the inners.
Old Jul 26, 2016 | 11:25 AM
  #2703
SquidBeak's Avatar
Pretty much the same here. I figured out a few tricks along the way. I'll probably start a thread with some pics soon. A hydraulic press sure would have been nice, though.
I had a feeling those boots would be a pain. Fortunately I didn't have any play.
I picked up the Harbor Freight ball joint removal tool. It worked great to remove my 14 year old ball joints!
Congratulations on the successful rebuild.
Old Aug 2, 2016 | 08:51 PM
  #2704
cornholio's Avatar
not today but this past weekend, i bought something worth equal to or more than my car to put on top of it
Old Aug 3, 2016 | 01:34 PM
  #2705
Itz Shak's Avatar
Way to go corn.
I finally fixed my gas needle problem by finding the right cluster. Even though it's 45k miles over what's really on the car
Old Aug 3, 2016 | 03:46 PM
  #2706
checka's Avatar
Currently trying to sell 2000 Maxima GLE. My son bought another car. Looking to sell the car together or as parts. $1000 or BO. Needs muffler system. Contact me.
Old Aug 7, 2016 | 05:09 PM
  #2707
ludeback2Max's Avatar
Got to drive it for the first time also changed all brakes and rotors with 2 new calipers(so much fun). Also found out I need new muffler yaaay
Old Aug 8, 2016 | 09:26 AM
  #2708
Reallyslowrio's Avatar
Yesterday I;
Finally installed the ES shifter bushings, the shifts are firmer, but still have the 3rd gear crunch.
Installed the NWP VIAS block off plate. Lost a little low end, but the top end screams now. I used to be able to just punch it off the light and roast the tires (along with some wheelhop), now it just pins you in the seat until about 3500rpms then the tires break loose all the way to redline. Feels like the powerband of my old turbo'd VW, and I love it.
Did the GAB, 8 3/4" holes. It's louder, but not aftermarket intake loud. Didn't really notice a difference performance wise.
Installed an AEM dry flow filter. The old one was a k&n and looked terrible. I never liked oiled filters on mass-air cars, so it got thrown in the garbage.
Went to the junkyard and found another 03 TE, so I robbed some parts off of it.
OEM drivers' headlight (my car had a DEPO light with a terrible HID in it)
OEM drivers' foglight (mine was broken)
Evap solenoid & charcoal canister. I broke the canister when trying to replace my solenoid.
Also acquired a free Test pipe from a 240sx that will be installed next weekend.
Fairly productive if you ask me.
Old Aug 9, 2016 | 05:38 PM
  #2709
tech2000's Avatar
Cleaned it up and finally took some pics with new wheels.
Attached Thumbnails 5th Gen: What did you do to your 5th Gen today?-20160809_192009.jpg   5th Gen: What did you do to your 5th Gen today?-20160809_191904.jpg
Old Aug 9, 2016 | 08:49 PM
  #2710
tech2000's Avatar
Raced a stock 2011 Maxima. Friendly race
5th gen vs 7th gen Maxima - YouTube
What's going on bro were you at the college park carwash a couple weeks ago?
Old Aug 9, 2016 | 10:02 PM
  #2711
Itz Shak's Avatar
Hey what's up man. Yeah that was me, you know we meet just about every Friday or Saturday.
Old Aug 10, 2016 | 03:06 AM
  #2712
tech2000's Avatar
Nothing much bro your car looked familiar in that video, that's cool I'll be there this week.
Old Aug 10, 2016 | 09:24 AM
  #2713
flames101sully's Avatar
Cleaned MAF, Thorttle Body, and air filter box. 16 years and it has not been cleaned once. Throttle body was filthy.
After cleaning them I thought the gas Gauge stopped working as it was staying at 1/4 tank (Took a Jerry can around just in case) , turns out it was just being more fuel efficent than it has been in years.
Old Aug 10, 2016 | 11:18 AM
  #2714
Itz Shak's Avatar
I bet she loves you now
Old Aug 16, 2016 | 12:48 AM
  #2715
dougmaxA33's Avatar
I installed a new timing chain and tensioners, wow, big job, but doable.
Old Aug 16, 2016 | 07:11 AM
  #2716
Had a custom 2.5-inch cat back made and installed. Exhaust guy said a 3" wouldn't fit with enough room so I went with 2.5
Knock sensor replaced
o2 sensor replaced
cleaned up the engine bay a bit
Old Aug 16, 2016 | 09:40 AM
  #2717
Mattx's Avatar
Originally Posted by VQ35maxima=Beast
Had a custom 2.5-inch cat back made and installed. Exhaust guy said a 3" wouldn't fit with enough room so I went with 2.5 Knock sensor replaced o2 sensor replaced cleaned up the engine bay a bit
Not that it makes much difference but a 3" fits without issue. Nothing wrong with a 2.5" it's a great upgrade either way.
Old Aug 16, 2016 | 08:12 PM
  #2718
That's what I was thinking, I've seen plenty of people with 3". Oh well hopefully I can feel somewhat of a difference lol.
Old Aug 16, 2016 | 08:56 PM
  #2719
Mattx's Avatar
It'll be fine. I just wanted you to know it can be done. 2.5" is fine unless you're going forced induction. If you do then 3" would be ideal.
Old Aug 17, 2016 | 01:28 PM
  #2720
Itz Shak's Avatar
I've had someone at a shop tell me the 3" wouldn't fit too. Until I made them do it themselves
