2002 Maxima GLE // Sway bar link and bushing replacement
Old May 14, 2013 | 08:21 AM
billm's Avatar
Can anyone advise what the flat labor time is to replace both front sway bar links and sway bar bushings?
I am receiving quotes ranging from 1 hour labor to 3 hours labor. The shop quoting 3 hours offers a lifetime labor and parts warranty.
Going to use Moog parts with lifetime warranty as follows:
K90431 - front sway bar link ~ $40
K90432 - front sway bar link ~ $40
K90587 - sway bar bushings ~ $20 each
Any recommendations on other brand of components?
Thx
Old May 14, 2013 | 08:23 AM
Fakie J Farkerton's Avatar
SUPER easy to do yourself.
Guess how much that costs??
I wouldn't pay more than an hour.
Edit: buy graphite impregnated polyurethane bushings if you can.
Never have to worry about those again IMO.
Old May 14, 2013 | 10:18 AM
SSJRICH's Avatar
Book time is 2 hrs for the bushings and 0.8 hrs for BOTH end links. (or 0.5 each)
Old May 14, 2013 | 10:53 AM
NmexMAX's Avatar
dot dot dot ...
Yes, very easy to do on your own. A jack, PB plaster, and a small 20$ set of metric sockets (if you don't already have one) will do, along with the parts needed.
Considering most shops labor rates, it's far easier/cheaper/efficient to do yourself.
Old May 14, 2013 | 11:14 AM
Rods03Max619's Avatar
Depending on the area, most shops will try and get over on you for install prices...
Old May 14, 2013 | 11:35 AM
SSJRICH's Avatar
+1 very easy. The bushings a little bit harder, but I did the ends links in about 3 mintues not including the time to hoist the car or take off the wheels... The bushings maybe 7.5 min cause I have to set up the air ratchet...
Old Dec 5, 2013 | 09:29 PM
maxiiiboy's Avatar
I need to replace mine (sway arm bushings), and the problem I have is:
1. Can I just remove/loosen the clamp that holds the bushing, slide/push the old
bushing out, then slide the new one in?
2. This may be too simplistic. If so, what ? .... Do I have to uninstall the entire sway
bar?
Thanks in advance - and I appreciate your advice !
Old Dec 8, 2013 | 05:56 PM
Mints33's Avatar
Depends where you're located, and how much corrosion there is, it can make a job a breeze or pita. I didn't have much luck replacing the end links, for they were seized on and the bolts stripped, so I had to cut and drill. That was NOT fun, took me many hours for that whole job. So take that into consideration if you are going to attempt it yourself.
kingw323
20
Oct 21, 2015 08:36 AM
Maxboy23
Aug 20, 2015 09:33 AM
fastcarny
Aug 12, 2015 03:50 PM
jerrod99_se-l
Aug 10, 2015 12:07 AM
yat70458
Aug 3, 2015 01:16 PM
