False hopes
Old Jan 14, 2002 | 06:56 AM
woosh's Avatar
False hopes
Hey .org,
Just wanted to know what ever happened to these. They made it seem doable and then never came back with anything:
1. The avalon ppl telling us how to adjust the throttle body to achieve 100% open (or are they keeping this 4 themself).
2. The ppl who wanted a test car(in the San Fran area I think) with an intake to finalize their ECU that would remove speed limit, and yield some HP.
Is anyone on the board cool with any of the violators that we could drop them a friendly poke, and ask them whats up.
Time 4 for some sponsibility!!!
cause me needs these mods...
Old Jan 14, 2002 | 07:17 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Not interested in #2. It's not a new ECU, but a piggyback ECU... and they want to charge full price.
Old Jan 14, 2002 | 09:11 AM
UMD_MaxSE's Avatar
Got Bent?
was #2 Weapon-R? They are kinda shady
Old Jan 14, 2002 | 11:05 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
TPS Sensor and TB Plate are doable...
If you have OBD software you can adjust the TPS from ~90% up to 100%. You mark the current TPS position, loosen the screws, rotate the TPS until you measure 100%, and retighten the screws. I'm just not sure what this will cause the ECU to do.
My TB Plate is not perfectly horizontal, but the only way I could see to adjust it is to file/dremel down the stop edge on the throttle cable reel. It hits on the TB housing, so unless you can diassemble everything I don't see a better way.
This is doable, but someone ELSE(READ Kevin!) has got to try this one first. Sorry.
Old Jan 14, 2002 | 02:38 PM
UMD_MaxSE's Avatar
Got Bent?
Re: TPS Sensor and TB Plate are doable...
that will adjust the TPS, but I think you will still need to make the throttle plate open up wider....
Old Jan 14, 2002 | 02:48 PM
IceY2K1's Avatar
Re: Re: TPS Sensor and TB Plate are doable...
Uhh. That's what I said.
Both changes will improve something, but whether or not it will be noticeable is the question.
Adjusting the TPS to 100% at WOT will allow the ECU to respond with more fuel.
Modifying the Throttle Body allows the throttle plate to open more horizontally and reduce turbulance into the manifold.
Old Jan 14, 2002 | 03:57 PM
Y2KevSE's Avatar
Yes, you hit it on the spot with the guess, Nauman.
Guinea pig?
Old Jan 14, 2002 | 04:39 PM
UMD_MaxSE's Avatar
Got Bent?
Originally posted by Y2KevSE
Guinea pig?
I'd do it, but I have had zero spare time lately no mods, no fun
TallTom
57
Oct 14, 2025 05:16 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
bernyp
Oct 2, 2015 10:10 AM
