Advance timing with android phone?
Old Jun 14, 2013 | 08:13 AM
  #41
NmexMAX's Avatar
dot dot dot ...
Originally Posted by JWatZ
Alright, tried to go back in this morning. It still read with the advance, but i couldn't adjust it or idle rpm. Just drove to work and tried once it was well warmed up and I could adjust both with no problem. I remember the engine temp has to be within a certain range even if being advanced with a Consult II, can someone verify that? Might help out those that are trying this out.
Yep, coolant temp needs to be at operating temp, 65ºC/150ºF or so. Same for IAVL, etc. Cipher wont let you do it, it will show the ECT in red, and right under it show the acceptable ranges, as it should
Old Jun 14, 2013 | 08:23 AM
  #42
rebelhell's Avatar
Originally Posted by NmexMAX
How much is it and where do I get it, (iPhone here )
We can't all have awesome Android phones.
Maybe pick up a cheap Android tablet? Might be worth it.
Old Jun 14, 2013 | 08:30 AM
  #43
CauzinDrama's Avatar
How so you maintain the 150 range.... My car warms right up to 195 in like 5-7minutes....maybe at the 150s for a minute
Old Jun 14, 2013 | 10:20 AM
  #44
TallTom's Avatar
I wonder if retarding the timing would work for pinging/knocking? Very interesting find regardless!
Old Jun 14, 2013 | 10:23 AM
  #45
NmexMAX's Avatar
dot dot dot ...
As long as it's between 150 and 220. Basically, above 150, I should have said.
220 and you've got problems.
Old Jun 14, 2013 | 10:58 AM
  #46
Oh yea... More problems than not being able to play with the settings.... Lol
Thanks for the info... Can't wait to get outa work now.
Old Jun 14, 2013 | 02:33 PM
  #47
JWatZ's Avatar
I see no reason why it wouldn't work on an Android tablet. Make sure it has bluetooth though.
It only allows adjustment from 0 to 2, can't retard the timing. I'm in contact with the developer and I ran some tests and logged them for him. I asked if he could add adjustment down to -2, we'll see.
Old Jun 14, 2013 | 05:51 PM
  #48
barristan's Avatar
stupid bluetooth. While your are talking to the developer ask them to add the option for USB control.
Old Jun 14, 2013 | 05:58 PM
  #49
Brl24's Avatar
Damnnn, this is seriously pushing towards an android for my next phone.
Old Jun 14, 2013 | 07:08 PM
  #50
HYPEsoon's Avatar
Just buy a cheap android phone off craigslist!
Old Jun 14, 2013 | 07:29 PM
  #51
JWatZ's Avatar
I've always had Windows Phones until my last upgrade to the Galaxy S3. Hated it until I found this little gem.
Old Jun 14, 2013 | 08:26 PM
  #52
MrEous's Avatar
^ Jeff™
If you're having pinging/knocking there's probably a larger issue you need to look into, rather than using the program as a band aid. IJS
Old Jun 14, 2013 | 08:46 PM
  #53
JWatZ's Avatar
Still would be a nice feature to have. Especially for those who want to cheap out on the octane level at the pump. But IMHO those people should buy a Honda instead.
Old Jun 15, 2013 | 04:19 AM
  #54
Timing up 2 degrees is making a noticeable difference in my fuel mileage. @ 350 miles I'm usually at 1/4 tank already. Everybody should be doing this as long as you use premium fuel.
Old Jun 15, 2013 | 04:49 AM
  #55
cjandura's Avatar
Fakie has a droid phone on the cheap for sale in the classy sections ijs incase someone needs it.
Old Jun 15, 2013 | 07:29 AM
  #56
Fakie J Farkerton's Avatar
Thanks.
Sold it on feebay though.
Old Jun 15, 2013 | 07:47 AM
  #57
JWatZ's Avatar
I see you have an ABS light, any success diagnosing with this app? I'll admit I haven't played around with it much.
Old Jun 15, 2013 | 07:58 AM
  #58
Yup... I knew what it was before I got the app but I used the app to verify and it found my left rear sensor is NFG.
Old Jun 15, 2013 | 08:16 AM
  #59
JWatZ's Avatar
Good to know. I just went through PID's for ECM, looks like I need a freon charge for the ac. Starting to like this app a lot.
Old Jun 15, 2013 | 09:52 AM
  #60
rebelhell's Avatar
Successful timing advance on my end...seems like a nice app so far.
Now I have to get these new upper mounts installed.
Old Jun 15, 2013 | 09:56 AM
  #61
ateick's Avatar
Great thread OP. Already have an Android just waiting for the OBDII adapter I ordered on Friday to arrive next week then I can start playing.
Old Jun 15, 2013 | 02:09 PM
  #62
Mikel81's Avatar
The app worked fine for me but was a little buggy at first. My car didn't seem to like having its timing advanced though. There was an immediate noticeable difference, and when I hit the gas the car stumbled and hesitated hard. I switched it back and it was fine.
Old Jun 15, 2013 | 02:26 PM
  #63
JWatZ's Avatar
Weird. Maybe do the relearns and try it again?
Old Jun 15, 2013 | 05:28 PM
  #64
cjandura's Avatar
Ok can someone list all the things this software can do for our cars?
Old Jun 15, 2013 | 05:54 PM
  #65
2damax's Avatar
Dude that would be a long list. I mean it can read anything the computer can read. O2 sensor voltages, MAF reading, coolant temps, injector readings, cooling fans on/off, a/c readings, fuel readings....the list is long. The obvious things that make this app better have already been discussed.
Old Jun 15, 2013 | 06:05 PM
  #66
JWatZ's Avatar
When the wife gets home with the car I'll snap some more screen shots. It's going to be a lot to post though, good thing there's not too many 56k users these days.
Edit: is there something specific you're looking for?
Old Jun 15, 2013 | 06:09 PM
  #67
ranmas2004's Avatar
I've done a little searching but haven't been able to find what discernible gains are to be had by a 2 degree advance. I'm guessing a bump in the low end? I'm sure someone has run the dyno numbers. Is there a link somewhere?
Try the dyno section next time.....
http://forums.maxima.org/dyno-discus...g-advance.html
Old Jun 15, 2013 | 06:31 PM
  #68
cjandura's Avatar
I want to compare it to Cipher sence uprev quit selling it standalone and wants to charge $400 for a package we caint use
Old Jun 15, 2013 | 07:39 PM
  #69
JWatZ's Avatar
Start here while I go out to my car to list this stuff.
http://scantech.proboards.com/
Old Jun 15, 2013 | 08:26 PM
  #70
cjandura's Avatar
Man if he can get the bcm functions and nats in there we would be good to go and more adjustment then 2* on the timing and maby some a/f readings and o2.
Old Jun 15, 2013 | 08:31 PM
  #71
Rods03Max619's Avatar
I was going to say you did one but forgot about it....
Old Jun 15, 2013 | 08:38 PM
  #72
JWatZ's Avatar
Alright CJ, this one is for you. Feel free to buy me a bottle of Jack via PayPal (j/k).
ECM Funcitons:
Self Test:
Idle Air Volume Learn, Self Learning Control, Idle RPM Adjustment (0-255), Ignition Timing Adjustment (0-2)
PID List:
AC Pressure, AC Pressure Switch, AC Relay, AC Signal, A/F Alpha Bank 1, A/F Alpha Bank 2, A/T Data 1 In, A/T Data 2 In, A/T Data3 Out, A/T OD Monitor, Air/P Control Solenoid, Absolute Pressure, Accelerator Sensor 1, Accelerator Sensor 2, Air Pump Relay, ambient temperature switch, atomosphere pressure, auxi control solenoid, bcm/sec, base fuel schedule, battery voltage, boost vacuum switch, brake switch 1, brake switch 2, can control vc sw, calculated load, cancel switch, catalyst, closed throttle, clutch p/p switch, cold start valve, coolant temperature, cooling fan 1, cooling fan 2, corrected idle rpm, corrected ignition timing, cruise lamp, distance switch, egr system, egrc solenoid 1, egrc solenoid 2, engine mount, evap system pressure, evaporative system, fqcal, ftvolnex, fuel control cylinder, fuel control engine, fuel injector bank 1, fuel injector bank 2, fuel level, fuel pump relay, fuel tank temperature, h02 bank 1 sensor 1 (*1, *2, *3), h02 bank 1 sensor 2 (*1, *2, *3), h02 bank 1 sensor 3, h02 bank 2 sensor 1 (*1, *2, *3), h02 bank 2 sensor 2 (*1, *2, *3), h02 bank 2 sensor 3, heated cat, heated 02 sensor, heated 02 sensor heater, heater fan switch, iacv ficd solenoid, iacv idle up, icc, ipdm e/r, idle a/v learn, ignition switch, ignition timing, inital diagnostic, intake air temp, intake solenoid bank 1 (*1, *2), intake solenoid bank 2 (*1, *2), intake timing bank 1, load signal, low speed cutoff, maf 1, maf bank 1, malprvl, malprvu, main switch, map/baro switch, meter/m&a, od cancel, od switch, p/n position switch, p/reg control valve, power steering signal, purge control solenoid, purge volume value 2, refrigerant, resume/acc switch, rev unit driver, rpm, swl vc switch, secondary air system, set lamp, set switch, shift solenoid a, shift solenoid b, start signal, susp unload, swrl cont, tcc solenoid, tcc switch, tcm, tprvl, tprvu, throttle relay, throttle sensor 1, throttle sensor 2, transmit diagnostic, travel after mil, usrvl, usrvu, vc/v bypass, vdc/tcs/abs, vias s/v, vvl s/v exhaust, vvl s/v intake, vvl solenoid, vari duct s/v, vehicle speed, vehicle speed cutoff, vent control, w/b solenoid bank 2, w/g solenoid bank 1.
ABS PIDS:
abs warning lamp, awd/4wd, actuator relay, ebd warning lamp, ecm, icc, initial diag, lf input solenoid, lf output solenoid, lf wheel sensor (same three for lr, rl, rr, not listing them seperately), meter, motor relay, off switch, rear input solenoid, rear output solenoid, strg, slip lamp, stop lamp switch, tcm, transmit diag, warning lamp.
You can also data log and graph any of these pids if you wish. Also the basic view codes, clear faults, blah blah blah. Don't think this will take place of Cipher if that was what you were hoping for.
When connecting I could not connect to TCM, SRS, BCM-40, BCM-42. Anyone else have luck? I kept getting an error message.
Old Jun 16, 2013 | 08:50 AM
  #73
I get the same....
And don't take this the wrong way JwatZ.... But you have alotta time on your hands to A: go out and research all the individual PIDs and B: post them all. You sir must have patience like a hospital... Lol
But everyone now knows everything this app can do for us, and for that..... I applaud you good sir.
Old Jun 16, 2013 | 10:07 AM
  #74
JWatZ's Avatar
I get the same....
Ehh, after the kids go to bed and the wife is asleep what is there to do? Didn't take to long, but i got lazy with the shift key before I got out of the A's, lol.
Also running some more tests for the developer, trying to figure out how to get negative adjustment of the timing and idle rpm. He added a list function for the self tests which make idle rpm adjustment a lot easier. Some of you could participate in this as well, just follow the scantool link I posted above. If your going to request some features please be courteous enough to run some tests for him if he pushes them through.
Old Jun 16, 2013 | 10:38 AM
  #75
Negative the RPMs huh...... I'm in....
Old Jun 16, 2013 | 11:20 AM
  #76
Brl24's Avatar
I realized that the gf has an android
I just have to order one of the Bluetooth OBD connectors, I didn't even know those kind of things existed.
Old Jun 16, 2013 | 11:33 AM
  #77
cjandura's Avatar
I hope this will run on my Nexus or Galaxy 2
Old Jun 16, 2013 | 03:12 PM
  #78
JWatZ's Avatar
Running it on a Galaxy S3, I don't see any other issues.
This is the one I'm using, works with this and Torque Pro
http://item.mobileweb.ebay.com/viewitem?itemId=221041165809
Old Jun 16, 2013 | 05:16 PM
  #79
I too am using Samsung Galaxy s3. And in the obd menu I looked at the device information and noticed my elm327 is running version 1.4b...so I ordered a new mini unit on stealbay that's version 1.5.
Old Jun 16, 2013 | 08:04 PM
  #80
TallTom's Avatar
Cancel your order if you can. ELM Never made a 1.5.
Please note:
There is no ELM327 v1.4a, or v1.5, or v1.5a ! Some clone makers have introduced what they call a 'v1.4a', or
a 'v1.5', or a 'v1.5a' but Elm Electronics has never made one.
http://elmelectronics.com/obdic.html#ELM327
