6th gen auto axle swap
Old Jun 17, 2013 | 02:02 PM
Mycoolg's Avatar
So I recently bought a 2000 maxima auto with hell of problems. One problems is the axles are horrible. So I was talking to one of my buddies and brought the idea of putting 6th gen axles in my car. His mom owns a 6th gen. I did some research and turns out the axles on the 6th gen are a lot bigger and durable. But couldn't find anything about anyone swapping them into a 5th gen most likely because the trannies are different. Just wondering if anyone has done it before? Or if it's even possible
If I can't find anything I'm likely gonna pull my out, and pull out the one out of his moms and compare and see if it's do-able
Old Jun 17, 2013 | 02:55 PM
Gemner's Avatar
if im not mistaken, much of the control for the 6th gen auto would take place over CAN, which the 5th gen doesnt have and the 5.5 gen barely has. Mechanically it might not be too hard, but the control could be a nightmare
Old Jun 18, 2013 | 06:41 AM
NmexMAX's Avatar
dot dot dot ...
Trannys are nearly identical (4AT for the 04, 00-03 4AT). So, going from a 6th gen to a 00 shouldn't be a problem. The other way around, I'd say it be a nightmare for control, like Gemner said.
When you say the axles are better, as in what way? Larger diameter, more splines? Hubs should be fairly similar too, just swapping speed ABS sensors would be the most difficult part.
Old Jun 18, 2013 | 10:02 AM
DennisMik's Avatar
With the 5th gen / 6th gen chassis being different, the length of the axles may be different also, so check carefully.
maxima-junky
Oct 21, 2015 05:17 PM
Fakie J Farkerton
Oct 14, 2015 06:25 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
maxima-junky
Aug 13, 2015 09:59 AM
