2002 cutting off at stop
Old Jun 22, 2013 | 09:43 AM
samwill65's Avatar
I bought my daughter a 2002 GLE a year ago, it is burning gas more than usual and it has started cutting off when she is stopped. It starts back up and drives without issue, but I have not been able to find the cause.
I have changed plugs, wires, air filter, and replaced the valve cover gaskets to stop a leak; all done about two months ago.
Any input would be great, Thanks
Old Jun 22, 2013 | 11:59 AM
DennisMik's Avatar
You didn't mention the check engine light being on, so I will assume that it is not. I will also assume that the check engine light bulb is burned out. Take the car to an auto parts store and ask them to read the codes. Then we'll see what to do next.
Old Jun 23, 2013 | 03:26 PM
TriniSpeC's Avatar
Shuts off on deceleration? Vacuum leak. How is the cold idle?
Old Jun 24, 2013 | 06:54 AM
Scottwax's Avatar
That's Mr. Detail to you
Dirty throttle body can cause stalling at low rpms, so can a malfunctioning EGR valve.
Old Jun 24, 2013 | 07:13 AM
Product_Of_Korea's Avatar
This
and also check the rubber vacuum line going from the intake manifold to the brake booster to see if its leaking
Old Jun 24, 2013 | 10:26 AM
ill12will8's Avatar
Camshaft position sensors. Most times they don't set off a CEL. But I did have a pending code for it
Old Jun 24, 2013 | 03:35 PM
Scottwax's Avatar
Had issues with my camshaft position sensors, never caused the car to stall though. My low idle and occasional stall after a hot restart on my 4AT 5.5 gen was my filthy throttle body. My son's Camry stalling problems was the EGR valve. EGR is easy enough to check, just block off the vacuum line going into it, cap off the vacuum line nipple on the EGR valve.
Old Jun 24, 2013 | 03:38 PM
ill12will8's Avatar
Well mines caused mine to stall. Also Auto 5.5 no harm in checking
Old Jan 5, 2014 | 07:42 AM
lidlitalian's Avatar
I am having this same issue. Anyone find the answer? Replaced: Iac, water temp sensor, coils, plugs, idle relearn, cpu reset, still stalls when cold. Heard might be upper manifold gasket?
Old Jan 9, 2014 | 07:37 PM
CDingfield's Avatar
I also had this problem and it ended up being a dirty MAF sensor. I just pulled it out and sprayed it with electronics cleaner and no more stalls!
Old Jan 10, 2014 | 01:09 AM
IceBerg's Avatar
Bad maf caused me to stall
Old Jan 10, 2014 | 05:31 AM
bennuss's Avatar
Same here bad maf caused me to stall.
Old Jan 10, 2014 | 07:42 PM
Phantasm's Avatar
Fuel Pump fixed mine
Once I replaced my fuel pump and filter it Fixed all of my stalling rough idling issues. At the time I had already replaced the EGR, MAF, vacuum lines, Valve gaskets and still had the idle issue. Even had the idle adjusted +250 rpms with Car Guage Pro (which then held it around 850) and it would still stall.
Now the idle is set about +25 (not 250) and holds a very steady 750-760 and no more stalling.
D Mason
Jun 21, 2016 04:43 AM
BobTX10
Oct 7, 2015 08:43 AM
RealityCheck
Oct 2, 2015 06:34 PM
09maxshawn11
Sep 30, 2015 10:28 AM
