Help me determine what the problem is ....
Old Jul 19, 2013 | 07:41 AM
watk2013's Avatar
2002 Maxima, 235,000 Miles. I have a hollow sound when slowing down and vibration at speeds around 60-70. Seems to be coming from the drivers side front tire. I've had the brakes replaced and rotated the tires.
I'm not sure if this is just a tire imbalance, or if this could be a wheel bearing issue, or control arm etc.
Thanks !
Old Jul 19, 2013 | 07:52 AM
FreshRichie's Avatar
That's probably the tires themselves. That was my problem. Replaced them, everything is fine now.
Old Jul 19, 2013 | 08:36 AM
jandk's Avatar
also look into your wheel bearings...
Old Jul 19, 2013 | 08:57 AM
TallTom's Avatar
I would say wheel bearings.
Old Jul 19, 2013 | 09:12 AM
Claybob86's Avatar
If you believe the sound may be coming from a wheel bearing, find an open road, get up to 20/30mph, then slowly steer/shift the weight of the car from left to right. If a bearing is bad, the sound will increase greatly when the weight is pressed to that side. (ie, if the left bearing is bad, it will get louder as you turn to the right, throwing the weight of the vehicle to the left).
user 11122324
42
Jul 18, 2022 03:35 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
Noela
Sep 26, 2015 08:22 AM
