6th gen to 5.5 gen motor swap. Upper oil pan swap. Which oil plate baffle to keep?!?
Old Jul 20, 2013 | 11:39 AM
nismopc's Avatar
So, in the middle of swapping upper oil pans, I noticed that there is an oil baffle plate on the '05 block AND a oil baffle plate on the '02 upper oil pan.
Which one to keep? I was planning on removing the '02 baffle and leave the '05 block as is, but wanted others ideas...
...this thread stated he removed the '02 baffle.
Originally Posted by MaxinO2
Another little problem I ran into today was swaping the upper oil pan to the new engine. It didn't have enough clearance to seal tight with the block. So here where it took a little thinking. The old 02' engine has a baffle screwed at the bottom of the upper oil pan where the 07' engine doesnt have a baffle in the same location. Its baffle is located at the bottom of the block where the very top of the upper oil pan meets. Both baffles don't work together at the same time so we removed the one from the 07' and left the baffle in the 02' oil pan.. The baffle is just something for the oil to move around.
Old Jul 20, 2013 | 11:43 AM
JonBlz's Avatar
a.k.a. STuNtMAN
When I did my engine swap with an 05 engine I kepted everything from the 02
Old Jul 20, 2013 | 11:45 AM
nismopc's Avatar
Also, anyone know what these would have been attached to internally? I found two of them in the '02 oil pan...
...pretty sure this is connected to why my engine blew.
Old Jul 21, 2013 | 04:57 AM
StevieB's Avatar
I think I ended up keeping the 06 baffle when I swapped, but I evaluated it probably made little or no difference. As for the screw...hmmm... I can't off the top of my head remember a Phillips head screw in the lower oilpan/block.
Old Jul 22, 2013 | 11:22 PM
tosheto's Avatar
I would keep the one from the newer engine. But I doubt it will make a difference which one you use. I have taken my VQ35 apart few times (don't ask) and have never seen screw like that anywhere.
Old Jul 23, 2013 | 08:32 AM
Gemner's Avatar
seems likely lol. Im not sure exactly what they are to, but they dont look designed to hold much stress, for a number of reasons, so I would venture to guess they go to something like the oil pickup tube, baffle plate, etc. (complete guesses) Of course, its also possible that they came from the top end and fell down through oil passages
also possible I guess that the screws came from someone accidentally dropping them through the oil filler
Old Jul 23, 2013 | 11:55 AM
murphys_law's Avatar
Whoah... Hmmm. Makes me curious. I would say that could be a very good indicator.
Old Jul 23, 2013 | 03:39 PM
DjHackStyle's Avatar
This is what i was talking about i think the screw belongs here.
Old Jul 24, 2013 | 12:51 PM
nismopc's Avatar
How about that!. Looks identical! At least from the top. I won't be tearing the old engine apart to find out exactly what blew/broke, but that gives me a pretty good assumption where the screws came from.
Thanks for the pic!!!
PH98I30
Jan 9, 2025 08:08 AM
Matt93SE
Apr 8, 2018 09:23 AM
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 11, 2015 12:23 PM
MaxStock
Aug 12, 2015 08:33 AM
