Maintenance at 168k?
Old Jul 22, 2013 | 06:43 PM
argenis69's Avatar
Hi, I have a 2002 Nissan Maxima SE auto with 168,000+ Miles. I want to do a complete service and check up(don't have past maintenance records). I'm looking to do it as soon as possible.
1- What specific parts do I need buy/replace, to do a Complete Tune Up and preventive maintenance? If possible, a complete list.
Thank you.
Old Jul 22, 2013 | 07:05 PM
2damax's Avatar
That was a super broad question since you have no history.
Spark plugs, RVC with 6th gen, gasket. Ooi change.Thats the most obvious tune up. Now how far do you want to go? Brake fluid, coolant, brakes, and check for common oil leaks. Keep an eye out if you burn oil. 6sp or auto? Clean maf and tb perhaps. List is long. Start with my first two sentences and see how it goes.
Old Jul 22, 2013 | 10:12 PM
DennisMik's Avatar
Add change oil in the transmission to the list. Change the struts.
Old Jul 22, 2013 | 11:00 PM
tosheto's Avatar
Oil, oil filter, spark plugs, air filter, pcv valve, clean MAF, new transmission and brake fluids, etc.
Old Jul 23, 2013 | 04:52 AM
cashman35173's Avatar
Thank you.
I would also check your hoses for dry rot and flush the radiator while your at it!
Old Jul 23, 2013 | 09:22 AM
argenis69's Avatar
Wow, that's a lot of things. What about the fuel filter?
Thank you
Old Jul 23, 2013 | 01:58 PM
RR5's Avatar
RR5
Maintenance has been covered here plenty of times. It's also covered in the FSM, in the MA section.
Old Jul 24, 2013 | 11:18 AM
argenis69's Avatar
I checked it out. Is it recommended to change the Auto Transmission oil? It doesn't say to change it on the manual...
Thank you.
Old Jul 24, 2013 | 12:55 PM
NmexMAX's Avatar
dot dot dot ...
I wouldn't change it at 168, especially if you do not know when it was last changed. How does it look, the ATF?
Old Jul 26, 2013 | 09:34 AM
argenis69's Avatar
Ill have to check. I asked around and most people say it's not good to change the ATF, and it tends to be worst for the transmission. Is it recommended at all to change the ATF?
Old Jul 26, 2013 | 10:18 AM
NmexMAX's Avatar
dot dot dot ...
If you had the car young and have done it regularly it's ok.
I bought my car at 39k in 2004 and do it every 10-15k. At 133k now, and need to do it soon. Semi soon.
Old Jul 28, 2013 | 04:15 PM
MaxinO2's Avatar
Any suspension part is probably pretty worn at that millage.. LCA's, ball joints, tie rods, end links, struts ect..
Old Jul 29, 2013 | 09:16 AM
argenis69's Avatar
Well, I had have the car for about 3 years and I've never changed the atf, and the manual doesn't talk about changing the atf, what is recommended for me to do?
Old Aug 1, 2013 | 09:51 AM
argenis69's Avatar
M?
Old Aug 8, 2013 | 12:18 PM
RR5's Avatar
RR5
The FSM will tell you.
Old Aug 10, 2013 | 02:41 PM
argenis69's Avatar
What is FSM? Does the transmission have a filter to change?
Old Aug 10, 2013 | 03:05 PM
Fakie J Farkerton's Avatar
Factory service manual.
Don't touch the filter. Not needed.
Old Aug 22, 2013 | 02:37 PM
RR5's Avatar
RR5
If the trans fluid has not been touched in a long while you will want to drop the pan and look at the filter. The new pan gasket usually comes with a filter so just change it out and make sure you take note if there is any metal debris which indicates a problem.
Old Aug 23, 2013 | 01:26 AM
Donkeypunch's Avatar
Why not change the fluid on high mileage?
I bought mine in 2006 and I've never changed the atf.
Never changed the air filter too until recently
That's another topic but there was a ton of sand and dirt caked on it. lol
Old Aug 23, 2013 | 08:15 AM
NmexMAX's Avatar
dot dot dot ...
Might cause the tranny to fail, detergents, etc will be removed and those were basically what were keeping it alive.
And there's not even a filter, it's a screen and a magnet. Drop the pan and see how they look.
Old Aug 24, 2013 | 12:35 PM
RR5's Avatar
RR5
Yeah I just experience that last week. Trans fluid was still pretty red and only had slight problems. I did a drain and fill but now I got slightly worse shifting problems. Soon it'll be time to send the valve body out for repairs.
TKHanson
Nov 24, 2018 01:39 AM
pears
Sep 18, 2015 05:25 AM
Jay556
Sep 12, 2015 05:50 PM
crazyespn
Sep 3, 2015 01:30 PM
