Bose sub amp fix 2002-2003 5.5 gen
Old Jul 26, 2013 | 10:43 AM
q.man06's Avatar
Hey guys, I was doing some looking around and it seems the bose sub amp is shared with several different vehicles- and they all have the bose sub cut out issue. Now, that being said I don't take credit for this at all, but it might help those searching for it.
I pulled this info by seaching for the bose amp PN which is 255490. This came off my 2003 6MT maxima with the 6CD bose POS system.
I'm going to get the part and install it tonight and report back. I hope this resolves my bose sub cut out issue!
COPIED FROM INFINITISCENE.COM
http://www.infinitiscene.com/forum/t...OSE-amp-repair
It looks like the links in the following quote didn't copy right, but they still work at the Infiniti forum link above.
Sup guys, I just got my 05 fx35 with the dreaded Bose system. While checking out the subs in the trunk area I noticed it was cutting in and out.
So I opened it up and behold its the same amp they used in my previous Mazda RX8. Well we had a fix and all it requires is a larger $2 Panasonic relay.
Items needed:
Your stock amp
Soldering iron
Rosin Core Solder
Solder sucker, wick, or pump
Digikey Panasonic JS1-12V-F Relay
Instructions:
Remove your stock amp, becareful with the white connector. It is a little difficult to remove.
Pry open the metal housing and remove the circuit board from the housing. The main board is held by one tab each side.
Locate and remove the old grey relay.
Exam your work, While the area is exposed, you will see 5 empty holes where the old relay was and 5 filled holes right next to it. We will be using the new filled holes. With your wick remove the solder that fills those new holes.
Solder on the new relay. If you care to, apply a very thin coat of rubber cement to the joints to protect from moisture.
Put everything back and enjoy the mediocre subs again.
Pictures: (note: these pictures and work was posted by gabrod72 on rx8club.com)
http://www.rx8club.com/attachments/d...ix-topside-jpg
http://www.rx8club.com/attachments/d...x-backside-jpg
http://www.rx8club.com/attachments/d...ay-removed-jpg
http://www.rx8club.com/attachments/d...lean-holes-jpg
Sources:
The thread: http://rx8club.com/do-yourself-forum...ay-fix-218790/
Link to the Relay: http://www.digikey.com/product-detai...2080-ND/648567
---------- Post Merged at 11:48 AM ---------- Previous Post was at 11:42 AM ----------
I just checked the part number Bose has for it, same exact amp as my previous car #255490. So relay should work.
Old Jul 26, 2013 | 03:41 PM
q.man06's Avatar
Just installed the new relay, and it powered up which is better than normal!
I'll give it a good test in the next few days and post back.
Old Jul 28, 2013 | 08:18 PM
Leroni35's Avatar
I used the .02 cent method and just folded a piece of cardbard and put the sub back together. I read it on an older thread about this issue.
Old Jul 29, 2013 | 12:02 AM
tosheto's Avatar
The links are not working for me for some reason.
Old Jul 29, 2013 | 06:36 AM
q.man06's Avatar
I did that too, I even re soldered the connections on the relay but that didn't help my issue. This is seeming to be a permanent fix. It hasn't cut out yet since the new relay
Old Jul 29, 2013 | 06:41 AM
q.man06's Avatar
It looks like it didn't copy the link right. Adding this link to the thread I copied here which I thought I had already added
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 11, 2015 12:23 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
MikesChevelle
Aug 19, 2015 07:19 AM
MaxStock
Aug 12, 2015 08:33 AM
