2000 Max replace coil packs or just spark plug boots
Old Aug 19, 2013 | 04:11 PM
Mike2000SE's Avatar
I have a 2000 SE, with about 140k on it. Runs fine, but has recently been stumbling/hesitating at certain speeds. It's done this before and it's been remedied by replacing the coil packs.
Looking at parts today, I realized that Rockauto.com now sells just the spark plug boots in addition to the entire coil packs. The boots are $10/ea versus $60+/ea for the coil packs.
Wondering if the main issue is generally with the boot or the coil pack? My guess is that I'm going to need to buy the more expensive part...but thought I would ask just in case.
Thanks,
Mike
Old Aug 19, 2013 | 04:24 PM
DennisMik's Avatar
I doubt that the coil boots will solve your problem. Before you replace the coils, try cleaning the throttle body and get a can of MAF cleaner and clean the MAF sensor.
Old Aug 19, 2013 | 05:38 PM
tosheto's Avatar
Boots don't do s***. If you have a misfire and your plugs are fine, find out which cylinder is misfiring and replace the whole coil.
Old Aug 21, 2013 | 10:47 AM
NmexMAX's Avatar
dot dot dot ...
Boots are usually only good if they're visually deteriorating. I had to use electrical tape on a few on my 4th gens, temporary band aid since boots weren't available back then. Not a bad option if yours are eaten up. But, since they're becoming more and more affordable, I'd say not a bad deal for the coil packs.
Old Aug 21, 2013 | 11:17 AM
dwapenyi's Avatar
It's most likely one of the rear coils (1,3, or 5).....they go bad more often than the fronts.
Old Aug 29, 2013 | 07:02 PM
Mike2000SE's Avatar
Thanks for the heads up.
Do you guys know the cylinder order? ie from passenger side back to driver front, the order of the cylinders?
Old Aug 29, 2013 | 08:10 PM
DennisMik's Avatar
Along the firewall, from passenger side to driver's side is 1, 3, 5.
Along the radiator, from passenger side to driver's side is 2, 4, 6.
Old Aug 30, 2013 | 04:41 AM
cashman35173's Avatar
I recently had the same issues. I would start with the MAF sensor first. It's the cheapest. If you have to change the coil packs, don't go aftermarket, It causes more headaches. Buy OEM!
Old Aug 30, 2013 | 10:38 PM
defiance's Avatar
Replacing Just the spark plug boots worked well on my 4th gen (96) as the old coils lasted forever,but the boots were heading south. So I replaced them with United Ignition Wire units from Rock Auto ran them for over a year and then sold the car. Worked out well !
vingodine
45
May 21, 2016 12:46 PM
Turbobink
Aug 15, 2015 07:20 AM
Balkins
Aug 12, 2015 06:39 AM
1992maximase30
Aug 5, 2015 09:27 PM
maxima297
Aug 3, 2015 12:50 PM
