Possible c/v axle problem??! Help!
Old Oct 19, 2013 | 11:27 AM
JayM's Avatar
Just put a new c/v axle on the passenger side of my 03 maxima, and now I sometimes get a clunk in my right front wheel, almost always when I'm turning and accelerating at the same time. Any ideas?!? I was thinking maybe I didn't tighten the ball joint all the way, I'm just so confused now.
Old Oct 19, 2013 | 11:45 AM
Nawlinsboy2006's Avatar
Where did you buy it from?
Reman or new?
I recently replaced mines and it was a reman from car quest. It makes the same clunk noise you are talking about. For $50 ill take the clunk noise over $500 OEM.
Old Oct 19, 2013 | 11:47 AM
JayM's Avatar
Originally Posted by Nawlinsboy2006
Where did you buy it from? Reman or new? I recently replaced mines and it was a reman from car quest. It makes the same clunk noise you are talking about. For $50 ill take the clunk noise over $500 OEM.
I remember I was hard up for cash so I bought one off eBay, like 80 bucks. I bought it a while ago though because a boot had torn and spewed grease everywhere for a while. Finally got around to it
Old Oct 19, 2013 | 12:16 PM
Same thing happen to mines. Think u got a new reman like me. Long as you don't feel a difference in driveability I wouldn't worry bout it.
I dnt plan on changing mines anytime soon!
Old Oct 19, 2013 | 05:16 PM
bennuss's Avatar
Check to make sure they re-tightened the sway bar end links. very often they are loosened to remove the axle. A clunk sounds like a not fully tight end link.
And yes the after market axles are absolute crap. I have one in and it feels like i am driving in gravel but interestingly only sometimes. ( I had the axle checked by multiple mechanics to make sure it is seated correctly so that does not seem to be the problem.)
Old Oct 20, 2013 | 09:19 AM
JayM's Avatar
Originally Posted by bennuss
Check to make sure they re-tightened the sway bar end links. very often they are loosened to remove the axle. A clunk sounds like a not fully tight end link. And yes the after market axles are absolute crap. I have one in and it feels like i am driving in gravel but interestingly only sometimes. ( I had the axle checked by multiple mechanics to make sure it is seated correctly so that does not seem to be the problem.)
Yea I had both of them done after the axle was done because the passenger side was broken. It never fixed the problem
matts95max
Apr 23, 2025 10:44 AM
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
