my car wont shift into any gears
OK I have a 2001 maxima anniversary edition 5spd, just yesterday my clutch pedal felt "sticky" I would press it down and it would stay stuck half way then just pop back out, well today I felt it doing the same thing, I checked my fluid and it was empty, so I poured clutch fluid. When I was getting ready to leave no gears would go in when I pressed on the clutch while the car was on. While the car is off the gears go I good. So I kept pressing on the clutch to see if there was air in the system, the clutch feels better now but still won't go into all of the gears
check and see if the clutch slave cylinder is bad and leaking, those can by symptoms of a bad clutch but if the reservoir was dry then theres a leak somewhere. check the lines etc. bad slave will cause you to not be able to go into gear as well
Lakersallday24
06-16-2019 01:35 AM
SmokinMax02
18
09-11-2015 12:25 AM
