Need help with starter problems.
Old Nov 17, 2013 | 06:10 PM
aut432's Avatar
Hi guys,
I am new here. Just bought a 2001 Maxima GLE. It rides awesome. Only problem is some times, it does not start. Its not a battery problem. Coz streo and everything works.
When i put the key in and turn it, I see all lights ON. i.e Brake, ABS, Etc.(like even though the brakes are not engaged) And when this happens, the car does not start.
But on occasions, when all is good, no lights are on, and it behaves normal and turns ON.
Also, all the steering buttons on the left seems to be short. All of them perform only one function, Increase the volume.
It would be really helpful if anyone could help me fix this. Thanks.
Old Nov 17, 2013 | 08:40 PM
Mike Travassos's Avatar
Do you have a spare key if so try using it see if your having the same problem,it mite be the security chip.
Old Nov 17, 2013 | 08:44 PM
CMax03's Avatar
Maybe all that carbon dust setting on the starter armature...But that's a sign it's time for another starter!
Old Nov 17, 2013 | 09:05 PM
DennisMik's Avatar
When the car does not start, does the engine crank over?
Also the way the car is designed, when you go to start the car and turn the key to the ON position (but not all the way to START) all the warning light will light up as a light bulb check.
Old Nov 18, 2013 | 04:33 AM
D.Stillwell's Avatar
Welcome to the site!
^^ Let us know if the engine cranks over when this happens, more info the better for us to help you...
From what you said it sounds like could be ignition switch/starter solenoid. You can test both. Easiest test is the starter, take metal part of screwdriver and jump starter solenoid (on left) to power connection (under rubber boot, on right) with key in "on" position and see what that does.
Old Nov 18, 2013 | 11:41 AM
aut432's Avatar
When the key is turned fully ON, the engine does crank but does not start.
Also, Yes, All the warning lights turn on when key is in ON position(but not all the way to START) . I dont know why this happens. I guess the computer is gone wrong or maybe the relays. What do you think
Old Nov 18, 2013 | 11:43 AM
aut432's Avatar
The starter was replaced only a month ago.
Old Nov 19, 2013 | 12:54 AM
DennisMik's Avatar
OK, this is progress. The engine cranking rules out the ignition switch as the problem.
All the warning lights coming on when you turn the key to the ON position is supposed to happen. This is a light bulb test so you know that they work.
It could still be a battery problem. If the battery is not holding a full charge, it may not have enough power to crank the engine fast enough, but your radio will still work just fine.
Is the SES light (check engine) on or off? I hope it is lighting up during the light bulb test.
Old Nov 20, 2013 | 08:07 AM
aut432's Avatar
The SES also get ON, Every light gets on. I guess which means it goes into light bulb test mode. But the problem i see is it does not come out of light bulb test mode. All the lights stay on. They are supposed to go Off right? And then the engine should crank like normal.
Also, Today I towed it to walmart and they said the battery was good. No issues with that. Not sure what to do next. Can you suggest what should I check for
Old Nov 21, 2013 | 12:12 PM
DennisMik's Avatar
When the key is turned to the ON position but do not try to start the car, most of the warning lights will stay lit up. I know the overdrive and the ABS lights do go off after a few seconds.
Another possibility is the park/neutral switch. If the car has an automatic transmission, move the shift lever to neutral and try to start the car. Wiggling the lever as you turn the key may help.
Old Nov 22, 2013 | 02:28 PM
aut432's Avatar
Thanks a lot for help. It was the key. It had gone bad and the car saw it as wrong key trying to start engine for more than 5 times and then it locked the system down. How stupid.
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
maxima297
Sep 30, 2015 03:32 PM
msellas
Sep 23, 2015 09:16 PM
aackshun
Sep 20, 2015 10:20 PM
