Courtesy FSTB is hindering spray nozzle. PLESE HELP NEWBIE!!!
Old Jan 17, 2002 | 04:40 PM
2k1BlackBeauty
Hello fellows, I am new here.
I just got my FSTB from Courtesy, but lately I realized that the nozzle is extremely weak, especailly on the driver's side. So today, I took the FSTB out and the problem is gone. However, I found no clearance problem inside the hood. My Nozzle is just gett ing really weak and I don't know why.
Is there anything I can do to reroute the windshield nozzle hose so that I don't have spraying problems???
Thanks.
Old Jan 17, 2002 | 04:41 PM
2k1BlackBeauty
Also, I have a 2k1 SE auto.
Old Jan 17, 2002 | 09:43 PM
CharlieNewbieMax's Avatar
Re: Courtesy FSTB is hindering spray nozzle. PLESE HELP NEWBIE!!!
Thanks.
maybe the fstb is pushing the hood up after u close it? that might cause the problem
Old Jan 18, 2002 | 12:49 AM
K Pazzo 6's Avatar
Old Jan 18, 2002 | 08:08 PM
Maksim2000's Avatar
Ok. since people are not being very helpful so far... j/k guys
Couple of things: didja remove those black rings on top of the towers before you installed the bar ? If not: do it it'll give it some more clearance to the hood liner(not whole lot though - still worth a try). If that doesn't work: On my car I just took the hose from behind the hood liner and routed it closer to the back of the hood... ugly but works. some people rerouted the hoose behind the hood liner so it doesn't get pinched with mixed results...
Max
Old Jan 18, 2002 | 08:47 PM
LeoB's Avatar
interesting angle
A lot of people here have been complaining lately of weak driver's side spray. Never thought about the fstb being the cause
thanx!
Old Jan 19, 2002 | 12:36 AM
y sleep's Avatar
If you do a search you will see this is a problem for some with the courtesy FSTB. The Stillen bar is flater. You may notice that if you pop the hood button inside the car (but don't lift the hood open)the driver's side nozzle starts to spray fine again. It seems the bar presses on the hood liner wich squeezes the nozzle tubing. I have been meaning to remove the hood liner to redirect the hose and then put the liner back on.
Old Jan 19, 2002 | 10:59 AM
Greg's2kGLE's Avatar
Hmm, I didn't have any black rings. Maybe it's just a SE thing.
Old Jan 19, 2002 | 11:04 AM
20 MAXIMA 02's Avatar
i have the courtesy bar on my car and there isnt a problem with the driver side nozzle.. u sure u tightened the bar down enough?
Old Jan 19, 2002 | 11:05 AM
Maksim2000's Avatar
I got a GXE... had these narrow black rings between the towers and the bolts something for stress releif I think.
Old Jan 19, 2002 | 11:07 AM
From what I remember I didn't have any, I could have though. It's been 10 months since I've had the FSTB on, so I could have forgotten about them. Oh well My friend's 00 SE had them.
Old Jan 19, 2002 | 11:14 AM
Vyrus's Avatar
Is your FSTB backwards?
-Cyrus
Old Jan 19, 2002 | 11:47 AM
Maksim2000's Avatar
Re: Is your FSTB backwards?
Originally posted by Vyrus
-Cyrus
Is that even possible ?
Old Jan 19, 2002 | 09:51 PM
zman187's Avatar
As greg says I had them, I put the courtesy on and I don't have any problems like that. Definatly a problem with when u close it though
Old Jan 20, 2002 | 05:39 PM
Jief's Avatar
Thanks.
Funny (and not), I dont have a FSTB (but seriously planning of buying one in the weeks to come) but I do have a nozzle problem (not a nose problem!). Mine is also weak, but on both side. Went to the dealer and he said it was ok (). Anyone with the same problem?
Old Jan 20, 2002 | 07:22 PM
Maksim2000's Avatar
Re: Re: Courtesy FSTB is hindering spray nozzle. PLESE HELP NEWBIE!!!
I would call nissan corporate and complain...
Old May 27, 2002 | 08:10 PM
Garfield's Avatar
Re: Re: Re: Courtesy FSTB is hindering spray nozzle. PLESE HELP NEWBIE!!!
I got the Courtesy FSTB last yr, but just got the nozzle problem this month. so, reroute the hose is the only way to solve the problem??
Old May 27, 2002 | 08:13 PM
Maksim2000's Avatar
Re: Re: Re: Re: Courtesy FSTB is hindering spray nozzle. PLESE HELP NEWBIE!!!
I guess you could get a higher pressure pump.. hehe . Yeah... you have to move the hose...
Old May 27, 2002 | 08:35 PM
Garfield's Avatar
well..then i'll do that this weekend...
thanks...
Old May 28, 2002 | 05:25 AM
mdeal's Avatar
I had the same problem with my Courtesy bar. That was almost two years ago and I have since replaced it with a Stillen bar. Re-routing the hose, underneath the hood heat shield, is about the only way to fix it. You'll probably not have enough slack in the hose to re-route that, so you'll probably need to pick up some extra hose. I removed that hood heat sheild thing once when I replaced all hoses with Hose Techniques stuff. It's not difficult but a hassle nonetheless.
Old May 28, 2002 | 06:14 AM
jarturo's Avatar
I had the same problem with the driver's side nozzle. Lift up the hood liner and reposition the feeder tube. It is hooked into a retainer clip - take it out and let it free float. It will not cause a problem.
Thanks.
Old May 28, 2002 | 06:28 AM
Hobert's Avatar
It seems like people are having issues with every bar except the Stillen...maybe they charge more because they actually design it to work without problems.
Old May 28, 2002 | 06:34 AM
Jief's Avatar
Put some baby powder on the bar and close the hood. You'll see where the bar is pushing on the hood liner.....
Old May 29, 2002 | 10:26 AM
Garfield's Avatar
Hi..
could u tell me where can i get the extra long hose from?
Thanks.
Old May 29, 2002 | 12:39 PM
Maksim2000's Avatar
Hi..
Thanks.
I didn't have to use extra hose. But you can get it at Pep boys or Advance or wherever... it's usually called vaccum/windshield washer hose.
Old May 29, 2002 | 12:43 PM
noflash's Avatar
Hi..
Thanks.
It's usually genetics!
Old May 29, 2002 | 03:31 PM
Triple8Sol's Avatar
I miss the .org!
doctorpullit
Apr 23, 2017 05:35 AM
trailer54
Nitrous
Nov 18, 2015 07:44 PM
Domf3
Sep 22, 2015 03:05 PM
bumpypickle
Sep 19, 2015 01:07 AM
