Alternator question!
Old Dec 11, 2013 | 09:31 AM
OutMaxxed's Avatar
Hello fellas! I have replaced my alternator a month ago on the Maxi due to low voltage. It ran beautifully with proper voltage after the install. So last night I noticed the dash lights slightly dimming when coming to a light.(like i have before the alternator went) I go home to check the voltage with the AC/lights/radio all on and it reads 12.6 volts. The battery is from Apr 2010. and I checked the voltage of the battery before starting it this morning and it read 12.3v.
When starting the car under load this morning the voltage went from 14.6v to about 14.1 after 25 minutes of idling. After driving around the block the voltage is at 12.7 under load. Could this be a my battery? Belts are tight, terminals are tight, there is some corrosion around the battery tie down but not the terminals.
I did note that with everything else on and the AC OFF, the voltage goes to 13.9. What could this be? Can it be my alternator again? It is a brand new unit not reman from MPA part # 15844N. Any feedback is welcomed.
Thanks guys
Old Dec 11, 2013 | 09:37 AM
Prophecy99's Avatar
i just replaced my alternator 3 weeks ago, and have the same exact dimming issues. and only do the lights get brighter with rpms.
I am thinking battery still for both of us.
Old Dec 11, 2013 | 10:11 AM
OutMaxxed's Avatar
Prophecy99 has it been dimming since the install? and which alternator did you purchase because after installing mine it was good for a month, Im starting to think maybe the cold weather is causing a weak battery? I really dont want to re-install the alternator again, it was a PITA.
Old Dec 11, 2013 | 10:23 AM
King_Ten_Ahead's Avatar
Id disconnect the battery and clean corrosion of the (terminals if theres any)
It sounds like a battery issue to me
Old Dec 11, 2013 | 11:08 AM
Nissan2000Maxima's Avatar
What's your batteries CCA (cold cranking amp)? Is the battery "big" enough to support our car, or is it a small Honda Civic battery? Size (CA&CCA) does matter in this instance. Also, if you have a spare battery, or a battery from another car, just swap them, it's fairly "quick" and can tell you if it is the battery or not.
Old Dec 11, 2013 | 11:12 AM
OutMaxxed's Avatar
its the correct battery for the car, ive always purchased the same group size battery. its like 24F or something like that i cant remember.
UPDATE: so with the headlights, fogs, and blinkers on and the car OFF. the battery voltage reads 11.4v...is this normal?
Old Dec 11, 2013 | 11:51 AM
SSJRICH's Avatar
Group 24 battery - you might also want to test your health of your battery, not just the volts. I see it almost every day where somebody says but I have over 12 volts... yes but that doesn't mean your battery is good. You need a more advanced battery tester than a volt meter. One that gives you CCA, Voltage, charge and state of health. Most shops and parts place will have one. Then you will know for sure if it your battery. Or just replace and see if it fixes your problem.
Old Dec 12, 2013 | 10:13 AM
Prophecy99's Avatar
i must say this, my battery was pretty much toasted from the alternator going on me (driving around a cpl days with the alternator going). So when the shop replaced my alternator they had to charge my battery overnight. So I'm thining the battery has been affected even after being charged overnight.
Long story short, I am thinking we should replace both of our batteries.
Old Dec 12, 2013 | 02:21 PM
SSJRICH's Avatar
Don't buy cheap battery's. And if you do, when it craps out after 2 years, don't act surprised. Just cause it says it has a 5 year warranty or whatever means squat
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
