how to get more acceleration
Old Feb 6, 2014 | 06:41 AM
Cameronn3712's Avatar
I have the 4 speed auto, and quite honestly, 1st gear is quite slow at low speeds. What do you guys recommend modding for more low end power? As of now, I have a cat-back exhaust and an air intake. I don't want to spend too much money. I've thought about doing a turbo install, but decided not to because of the price. Soon, I will also be doing a full tune-up, and replacing my struts and springs.
Old Feb 6, 2014 | 06:48 AM
NmexMAX's Avatar
dot dot dot ...
Buy a s6MT or different car.
Old Feb 6, 2014 | 07:10 AM
TallTom's Avatar
a turbo wouldn't give you low end power regardless.
Old Feb 6, 2014 | 07:12 AM
NmexMAX's Avatar
dot dot dot ...
Playing devils advocate, but, that would depend on his turbo set-up, of course at the compromise of high end hp.
Old Feb 6, 2014 | 07:30 AM
Amerikaner83's Avatar
want more acceleration at low speeds? turn the overdrive OFF and punch the gas harder.
Old Feb 6, 2014 | 07:50 AM
NmexMAX's Avatar
dot dot dot ...
No OD button on the 5.5 gen.
Also, while at speed, ~ 55+ MPH, going back into 4th, in your case (4th and 5th gen) OD ON, gives a jump for a few RPM's and aids in better acceleration.
Jime covered this quite nicely many moons ago.
Old Feb 6, 2014 | 07:56 AM
OP has a 5th gen...do they not have o/d buttons either? and he said first gear, not freeway speeds, yes?
Old Feb 6, 2014 | 07:58 AM
ac max 92's Avatar
I can't think of the product name but there is a product that installs to your electronic throttle body and has 3 settings that adds some extra pep. I will see if I can find out the name of the product and if it will work with your vehicle.
Old Feb 6, 2014 | 08:06 AM
colt149's Avatar
How to get more acceleration
Install PCV oil catcher
Install 75 mm big bore throttle body see the link below
http://www.nwpengineering.com/
Old Feb 6, 2014 | 08:10 AM
NmexMAX's Avatar
dot dot dot ...
OP has a DEK, no TBW. And you probably mean the SprintBooster.
Well FML, that's the problem then. 4AT + 5th gen chassis + VQ30 = FTL re: initial acceleration.
Not available for the DEK, and DEK's don't burn oil like the VQ35.
Old Feb 6, 2014 | 11:30 AM
ac max 92's Avatar
Thank you. Yes it was the sprint booster I was thinking of
Old Feb 7, 2014 | 11:55 AM
TravisCadello's Avatar
Buy a new car. U won't ever get good low end power. You want that buy a diesel truck.
Old Feb 7, 2014 | 12:33 PM
Donkeypunch's Avatar
That sprint booster thing looks like total rice.
Basically it tells the throttle to open more vs how it used to open when
pressing the pedal.
It's just tricking you but really you're just giving it more throttle.
There's no cheap or free bolt on things that turn these cars into GTRs.
Old Feb 7, 2014 | 12:44 PM
Fakie J Farkerton's Avatar
People don't come on this site to be told to buy a different car FFS.
Your not helping answer his question.
If it was "Should I continue to do performance mods or buy a new car?" then sure, maybe.
I'm not sure why you would say that anyways considering you have power mods on your Maxima too.
Old Feb 9, 2014 | 07:22 PM
metalpiotr's Avatar
03 Maxima, 6spd
For a 2000? Y pipe should help with power.
Old Feb 10, 2014 | 04:05 AM
george__'s Avatar
light weight rims
Old Feb 12, 2014 | 05:40 PM
MaximaJeff02's Avatar
It wont help that much with off the line, but it'll give you a kick you can feel in the higher RPMs. The NWP intake manifold spacer kit. They're affordable too.
Old Feb 12, 2014 | 06:02 PM
Old Feb 12, 2014 | 06:24 PM
foodmanry's Avatar
Da Roller Coaster!
I can't believe no one has asked this yet...but what kind of air intake does the OP have? The type of aftermarket air intake will affect low end power.
When I had the crappy Injen intake the low end was terrible. After I went to a modified short ram intake the low end greatly improved.
Old Feb 12, 2014 | 08:31 PM
Suuuurrreee.
Old Feb 12, 2014 | 11:17 PM
ABIGBRAIN's Avatar
Edge Racing torque converter... 3000 stall.... $450
You will still have the lock-up function in OD and the car will pull from a dead stop much harder.
Old Feb 13, 2014 | 04:42 AM
D.Stillwell's Avatar
YPipe + gut your cats or get headers = will give you most punch
Bigger exhaust, nwp spacers, timing advance, good intake
and then get a shift kit, will feel much better after that
Old Feb 13, 2014 | 06:46 AM
NmexMAX's Avatar
dot dot dot ...
Old Feb 13, 2014 | 07:05 AM
dwapenyi's Avatar
How long have you had the car? Do you have 17" rims? I think what you might be feeling is the fact that a 3.0 liter V6 pushing a 5th gen body (~200 lbs heavier than the 4th gen Maxima) with 17" rims takes a little bit away in terms of performance. Ever wonder why Nissan decided to go 3.5 V6 in the middle of the 5th gen's model run?
If you really want some pep while keeping OEM as much as possible, I would suggest downgrading to 16" rims and tires and a full tune up, including changing the primary O2 sensors. The O2 sensors may still work but may be tired if they've never been changed in the past 100K miles or so.
Another thing to consider is that most autos start off in 2nd gear instead of 1st to save gas.
Old Feb 13, 2014 | 12:15 PM
SSJRICH's Avatar
What you do is download Highway to the Danger Zone, put on the aviators and crank it up to 11 and trust me you will feel like you are going faster!!!
Baring that... DONT WASTE YOUR MONEY! spending thousands on little things is not going to help. Auto is just slow off the line, and unless you are going to swap in a manual (thousands$$$) or do something dumb like turbo or NOS (thousands$$$)
Old Feb 14, 2014 | 04:27 AM
95VQ30's Avatar
trans go maybe..?
Old Apr 10, 2014 | 03:07 PM
Itz Shak's Avatar
Good point about the gear shifts, and sensors!
Old Apr 10, 2014 | 07:11 PM
Zericmz's Avatar
Lol maybe the prices are stupid high where you are at but in Nebraska it doesn't cost thousands to do an AT2MT swap. You can snag a CMC and Slave cylinder new for roughly 150 depending on brand, 150 on the transmission, and maybe 50 bucks max on the pedal assembly. The rest is time and motivation.
Also in regards to the Injen intake being doggy during low end, whenever my Maxima is running in it's prime I feel the intake is excellent and provides quick and snappy acceleration into the upper rpms where I feel it also does excellent.
Old Apr 10, 2014 | 08:37 PM
Quickywd01's Avatar
Warpspeed y-pipe, lightweight rims and tires, vb upgrade, supra stick, etc.
Old Apr 10, 2014 | 10:49 PM
maximasicilian123's Avatar
Always start with a full tune up. Gas filter and cabin filter. Seafoam. Maybe change trans fluid. Make sure u have no codes. 02 sensors would help too even with no codes. And clean the mass air flow sensor. I know its tuff on a budget just do what u can little by little.
[QUOTE="maximasicilian123;8939387"]
Always start with a full tune up. Gas filter and cabin filter. Seafoam. Maybe change trans fluid. Make sure u have no codes. 02 sensors would help too even with no codes, new coils , And clean the mass air flow sensor. I know its tuff on a budget just do what u can little by little but try not to get the cheap **** especially from eBay or Amazon. Ngk plugs, oem coils , and quality 02 sensors
Old Apr 11, 2014 | 12:45 AM
kauaiwyatt's Avatar
if your motor mounts are shot, get new ones. That helped a lot with my old 5th Gen.
Old Apr 11, 2014 | 12:58 AM
george__'s Avatar
Even with the HD2 kit, the car sucks until after gear 1 and there is that 1-2 kick
Old Apr 11, 2014 | 01:06 AM
Old Apr 11, 2014 | 01:36 AM
Originally Posted by Fakie J Farkerton
Wtf u got nothing else to do?
Old Apr 11, 2014 | 01:42 AM
Old Apr 11, 2014 | 01:50 AM
:sselesu:
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
Maxxx10
Sep 13, 2015 03:16 PM
jcvgn
Sep 10, 2015 08:03 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
