Quote:
Al calipers, outdated design, etc.
Would any semi-loaded calipers work seeing as I am going to use aftermarket brake pads? Also I guess that there is a left front driver and right front passenger caliper and they cannot double as the same part. There are just so many random brands of calipers like a1 cardone, centric, powerstop, raybestos, and I am really not sure which one to choose from as they may all vary reliability wise. Originally Posted by NmexMAX
Is there any place to just get regular 6th gen semi-loaded calipers at a decent price instead of wandering around aimlessly on the internet looking at no name calipers that will probably get me into a future crash?
And semi-loaded calipers are everything I need, mounting brackets and such as well as caliper with no brake pads, right?
Don't exactly understand everything you wrote above Bishop but here is what I think you are looking for in an answer.
If you want to do the 6th gen BBK you will need:
- 6th gen calipers. Yes there is a right and left side. They are different.
- 6th gen brake pads. If you buy loaded calipers then you won't need to buy pads.
- 6th gen rotors.
Disconnect brake lines, remove calipers, pads and rotors. Replace with new rotors, pads and calipers. Reconnect brake lines and bleed the brake system.
Raybestos, centric, cardone are all known brands. You should be fine with them. Just beware of no name ebay brands.
This is a basic setup that will be far superior to the OEM setup currently on your car. There are other options if you have patience for them but they can require additional adapter brackets, etc..
- 6th gen rotors.
@OP - go to vendor section and talk to importrp. You also need gen 6 brake mounting hardware which can be bought from dealership
Also there is a section on here for that.it will tell you everything you need to know.
Becareful of george_ advise it can get you stuck
Quote:
No you don'tOriginally Posted by george__
Quote:
Yeah you are right I called it the wrong thing - it is the 6th gen front brake shim kitOriginally Posted by ateick
No you don't
http://forums.maxima.org/5th-generat...e-upgrade.html
Wrong again. First you say mounting hardware and now shim kits. George you're going to send this guy searching for things he doesn't need. The post you referenced talks about OEM pads which apparently need a shim kit. Most pads do not. They come included.
There should be a sticky that says don't listen to George....
All you need to do is search his threads and you will know why....
Listen to everybody else - especially those of use that have actually done it ourselves
Yeah I had a general idea of the task at hand which quite frankly isn't that big of a challenge at all. And yes I have heard about George all the way outside of the org on a Facebook page.
Quote:
Crap, one last question, sorry to bother, but if I order loaded calipers, does that include the caliper bracket as well since it is "loaded"?Originally Posted by ateick
If you order loaded then you get the caliper and pads together in one package. All you would need at that point would be rotors to do the swap. Everything will just bolt on.
Alright parts coming in thursday, hopefully will install Friday. Thanks for all the help guys.
Sorry to re-ignite this thread. But couldn't you just order the power stop kit part#KC091 and it have everything you need? Instead of trying to track down and pay for all the parts separately. I have no experience with this kit or powerstop just figured this would be a one stop shop and make it really easy for anybody interested in the upgrade. Rockauto has the kit for 250 I believe plus shipping. Just trying to help out.
http://www.powerstop.com/products
I've actually thought of doing this soon cause I know my rotors are to thin to be turned for the next pad change.
See what you guys think
I just bought my Dad's beloved 2003 Maxima and I need a full set of brake, but after reading this thread I'm really confused.
To clarify: If I purchase rotors, pads and calipers at Napa for a 2004 Maxima, I will have everything I need to do the job. These parts will drop in with no mods. Correct?
And what rubber floor mats do you guys recommend? I'm thinking about WeatherTech.
Not a 5th gen but just did the 6th gen BBK upgrade on my 4th gen. It's alot more work to put these calipers on a 4th gen than it is to put them on a 5th gen but definitely worth it!
Quote:
You cut off all the dust shields?Originally Posted by nismomaxgtr18
Quote:
Not completely. (excuse all the surface rust; was cleaned up before everything was assembled)Originally Posted by Fakie J Farkerton
Quote:
Thanks for the photo!Originally Posted by nismomaxgtr18
I'm doing this as soon as I get my new bearings.
Finally installed these bad boys
. I also recommend a bleed and flush with new brake fluid.
doesnt look like muchh cause the gle wheels kind of hide the big rotors but the stopping power is much more compared to the stock fade prone rotors.
They are definitely a stealthy setup that pack a punch.Originally Posted by bishop8520
Quote:
Yeah just 6th gen calipers with 6th gen brackets and 6th gen front pads. SE wheels clear the calipers by about 1mm I have read and GLE wheels have plenty of space to spare. No modifications needed since its just a simple bolt on swap.Originally Posted by heyhi
5.5 gen needs no modifications for the 6 gen brakes? Any year 6 gen?
outdated design? Do tell how caliper technology has changed in the last 20 years? Its a simple piston pushed by hydraulic fluid with seals clamping on a piece of metal to create friction. Thats like calling socks outdatedOriginally Posted by NmexMAX
But if we must, I
this comment,Quote:
I challenge anyone to a braking contest w/ z32 calipers.
Or, someone send me a Z32 caliper, bracket, rotor set and I will throw it in my braking test.
To the OP....
Your answer was given already, just get a 6th gen brake kit, and just tell the next owner which brake pads and rotors to buy, mention nothing of the upgrade.
Originally Posted by aackshun
Z32 is purely a bling mod these days.I challenge anyone to a braking contest w/ z32 calipers.
To the OP....
I've had A34 brakes, Z32TT brakes, Wilwood brakes and EVO brakes on this car. So, yeah.
