Looking for a little help.
Old Mar 20, 2014 | 08:55 PM
Blackwolf11377's Avatar
My 2000 maxima 5 speed jerks when cold around 1k-2.5k RPM
also after 4k rpm i get no power it takes a poop
also i can pop the gears out without using the clutch but cant put it in gear without the clutch ( found this out 2 days ago)
also my foglights/ powerlocks / interior lights dont work
please i need a fix to these problems or links
thank you!
Old Mar 21, 2014 | 07:38 AM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/4th-generat...e-contest.html
Old Mar 28, 2014 | 07:35 AM
bump
Old Mar 28, 2014 | 10:40 AM
DennisMik's Avatar
I would like to propose that we change the name to "Who can create the least informative subject line?"
Old Mar 28, 2014 | 10:57 AM
DennisMik's Avatar
thank you!
We always ask the question: Do you have a check engine light on?
You can always take the transmission out of gear as long as you are not accelerating or decelerating. You can put the trans in gear while you are moving if you match engine speed to the land speed for the gear you are trying to engage. This is called double clutching.
The fog lights could be one of 3 things (in order of likelihood):
1) the socket for the light bulb could be corroding and the wires are not making a connection.
2) switch on stalk is bad
3) fog lamp relay is bad
Interior lights could be a fuse. But which lights are you referring to? Every light inside the passenger cabin is an interior light. You have the dome light, the map lights, the step lights, the dash lights, etc. Would you please clarify.
Old Mar 29, 2014 | 05:14 PM
1badmaxipad's Avatar
OP,
I had a similar problem to my maxima when I first got it, that is, your sputtering and not going over 4,000 rpm thing (I never had an electrical problem).
It ended up being the MAF.
Old Mar 29, 2014 | 05:23 PM
george__'s Avatar
+1 the maf
Taino14
Sep 24, 2015 02:51 PM
hozay99
Sep 19, 2015 10:20 PM
pears
Sep 18, 2015 05:25 AM
