03 VIAS issues
Old Mar 24, 2014 | 05:09 PM
ACee's Avatar
03 VIAS issues
I purchased a used vias online and took it to my local national auto parts store to buy some vacuum hose. The employee took my vias in the back to match up the vacuum hose and came back to me with a broken vias nipple. Evidently, it broke when the employee pulled the vacuum hose off one of the two nipples. They've been trying for two weeks now to find me a replacement vias and no such luck.
The nipples are too big and the solenoid electrical connector isn't the same on all of the three I've seen.
Thoughts?
Old Mar 24, 2014 | 06:03 PM
The_Fixer's Avatar
Vias delete and BOP! Problem solved get the parts store to pay for the fancy NWP vias BOP
Old Mar 24, 2014 | 06:08 PM
ACee's Avatar
I like that! Just not sure exactly how to delete... I've read some posts but still a little uncertain on how to do it.
Old Mar 24, 2014 | 06:34 PM
george__'s Avatar
Old Mar 24, 2014 | 08:59 PM
schmellyfart's Avatar
www.nwpengineering.com
Old Mar 25, 2014 | 03:50 AM
ACee's Avatar
I must be confused....
This is the part I need
http://rs993.pbsrc.com/albums/af58/a...da.jpg~320x480
Old Mar 25, 2014 | 04:54 AM
george__'s Avatar
http://www.nwpengineering.com/NWP%20...IAS%202011.pdf
You can buy the block plate from NWP and then install it... It removes the vacuum hose going from the VIAS to that thing you pointed at but the hose going from that thing to the black canister has to be there?? (or it throws a code I think)
Also did you check www.car-parts.com?
Old Mar 25, 2014 | 05:46 AM
ACee's Avatar
^ I think I found the part I need. It is part no. 911506
Old Mar 25, 2014 | 05:48 AM
george__'s Avatar
Here you go
http://www.courtesyparts.com/maxima-...1958_1971.html
Old Mar 26, 2014 | 04:56 PM
Rochester's Avatar
Here. Pictures are easier than words. Car is smoother without the VIAS. You loose some low-end torque, but it ramps up more pleasantly with a little added high-end HP. Works better if you're modified a little... spacers, exhaust, intake.
Coincidentally, I found my old VIAS, lines and vacuum tank in the attic last month. Threw it in the trash. (Oops ) Never occurred to me to try and sell it here.
Mar 12, 2020 12:06 AM
trailer54
Nitrous
Nov 18, 2015 07:44 PM
Kalrakam
Sep 16, 2015 12:30 PM
0m3nc0w
Sep 11, 2015 05:21 PM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
