Just bought 03 maxima. Would like pointers
Old 03-29-2014, 05:41 PM
  #41
george__'s Avatar
Originally Posted by alanfury
Thats a great start! I am just getting started as well. What intake did you put on?
JWT popcharger
george__ is offline
Old 03-29-2014, 10:43 PM
  #42
svillegas2253's Avatar
Originally Posted by Garrettz459
Would you mind post a picture of your car please? We all would like to see it!
svillegas2253 is offline
Old 03-29-2014, 11:13 PM
  #43
Fakie J Farkerton's Avatar
Your car has an extra cat in the front.
Fakie J Farkerton is offline
Old 03-29-2014, 11:38 PM
  #44
Using that for now.. Switching to a short ram though. What are you using?
Haha dont mind the neighbor's cat
Old 03-31-2014, 07:06 PM
  #45
Garrettz459's Avatar
Sweet ride you got there mate! I'm expecting you to lower your ride! The car is begging you to low it her!
Garrettz459 is offline
Old 03-31-2014, 07:11 PM
  #46
Thanks. Loving this thing lol.
Working on bolt on mods like y pipe, intake spacers, vias block off plate for now
But yea eventually I will lower it and switch the wheels out with G35 18s
Old 03-31-2014, 07:21 PM
  #47
george__'s Avatar
yes please lower it
george__ is offline
Old 03-31-2014, 07:24 PM
  #48
maximasicilian123's Avatar
http://www.nwpengineering.com/
http://www.letmegooglethat.com/?q=Ma...+throw+shifter
[URL="http://www.letmegooglethat.com/?q=magnaflow+resonator"]http://www.letmegooglethat.com/?q=magnaflow+resonator[/URL
http://www.letmegooglethat.com/?q=O2+simulator+install
What a good girl u finally said something useful. Has anyone done the 75 mm throttle body? If so how do you like it? Do u feel a difference? Can I do this and feel it with just a ypipe and exhaust?
maximasicilian123 is offline
Old 03-31-2014, 07:31 PM
  #49
I ask myself the same question since im doing the 5pc intake spacers, dont know if its worth buying the bigger tb
Old 03-31-2014, 07:35 PM
  #50
george__'s Avatar
Not really. Use the $500+ towards your coilovers
george__ is offline
Old 03-31-2014, 08:07 PM
  #51
I just saw a video on YouTube that the guy was having a problem with vacuum leaks from the spacers.he redid it 4 times 2 different mechanics and finally took them off.
Literally just finished watching it and came on here.
Watch "Why I Removed My NWP Spacers" on YouTube
Old 03-31-2014, 09:40 PM
  #52
So then maybe getting a gutted manifold and 75mm tb might be a better idea??
Old 04-01-2014, 12:11 AM
  #53
Im not sure still doing research on it.same boat as you. That guy might of had defected spacers or it just could be a problem more people have.what kind of intake are you using?
Im looking into intake exhaust and maybe 75 mm if Im confident enough that its worth it. Another thing I wanna figure out is a good clutch. I read fidenza with a 350z stock clutch is a good combo.but that's later on.and I wanna get a good suspension combo.
Well I already ordered and will be installing spacers myself. Most people have had no trouble. Hopefully it works well.
As for the clutch im thinking the same thing. I give my clutch about another 2k miles before I switch out
Using that for now, switching to short ram though
Let me know how the spacers work out. Im changing my plugs so might as well do that too.
Old 04-01-2014, 05:04 AM
  #54
95VQ30's Avatar
OP- don't worry about power down low, you want to get more power up top.
Spend less that $200 and do these following upgrades
VIAS BOP plate from NWP
Spacer Kit from NWP
STS mod
(all can be done in your driveway with a couple/few hours and simple tools)
Then I'd recommend Headers, exhaust, suspension, RSB or brakes
Don't worry about the throttle body unless you plan to upgrade your intake manifold
95VQ30 is offline
Old 04-02-2014, 08:26 AM
  #55
Excellent choice for the rims!!
Old 04-02-2014, 02:16 PM
  #56
dot dot dot ...
NmexMAX's Avatar
That's a very rare case. And I did mine successfully 5-6 years ago with no problems. Also removed them and put them on another manifold 2x, still no problem.
One idea to try is to use 2 OEM gaskets for the LIM/UIM for easy installation because that RTV is a to get off, especially if you plan on re-using it.
http://forums.maxima.org/5th-generat...ml#post8194111
http://forums.maxima.org/5th-generat...p-spacers.html
NmexMAX is offline
Old 04-02-2014, 05:06 PM
  #57
Yup Im waiting for my spacers to arrive so I can get started
Picked these up the other day on CL. Havent thrown them on cause the front tires are shot
Old 04-03-2014, 12:28 PM
  #58
alanfury75's Avatar
[QUOTE=svillegas2253;8934666]Name:  20140329_230118_zpsmczugor1.jpg
Ah man that's pretty sweet! I'm still running stock intake... looking into some options.
alanfury75 is offline
Old 04-03-2014, 12:48 PM
  #59
tcb_02_max's Avatar
Are you kidding me? Am I the only one who thinks the tubing on this intake looks really small, not smooth/constant diameter, and like it is sucking hot air from behind the radiator? I can't be sure, though, because it is hard to determine such details only from a picture.
tcb_02_max is offline
Old 04-03-2014, 01:57 PM
  #60
Yes you are right. Its not the best intake, but like I said I threw it on because I already had it. Just for the meantime while I find a good one (short ram)
What brand is most recommended?
Old 04-03-2014, 03:07 PM
  #61
dot dot dot ...
NmexMAX's Avatar
JWT POP charger or similar. (AKA build your own)
https://www.siliconeintakes.com/
http://www.bpi-us.com/stacks.php
http://www.spectreperformance.com/ca...?cat=C00000271
http://bloxracing.com/shop/index.php...ory&path=59_83
http://www.aemintakes.com/dryflow_air_filters.htm
http://www.sbfilters.com/index.php/p...l-filters.html
A GAB is better than what you have there, and I'd be willing to say a stock airbox is better too.
NmexMAX is offline
Old 04-03-2014, 05:57 PM
  #62
Anyone know of a write up on making a cold air intake? Can't find it. Need something that shows locations and if I have to relocate the battery
Old 04-03-2014, 06:17 PM
  #63
Old 04-03-2014, 08:50 PM
  #64
dot dot dot ...
NmexMAX's Avatar
Last time
http://forums.maxima.org/5th-generat...ir-intake.html
NmexMAX is offline
Old 04-03-2014, 09:18 PM
  #65
george__'s Avatar
For the spacers - USE A QUALITY TORQUE WRENCH and make sure it works (calibrated properly etc)
george__ is offline
I<3 A32's
09-10-2015 11:07 AM
Violator
09-09-2015 10:14 AM
nbstriker10
09-04-2015 04:26 PM
crazyespn
09-03-2015 01:30 PM
Quick Reply: Just bought 03 maxima. Would like pointers
