View Poll Results: bose system cutting out?
bose
100.00%
pac-roemnis2
0%
nissan
0%
maxima
0%
se
0%
2001
0%
system
0%
wire
0%
harness
0%
aftermarket deck
0%
Voters: 1. You may not vote on this poll
Why does my Bose cuts out.
Old Apr 2, 2014 | 08:51 PM
teejay1786's Avatar
hello i was wonder if anyone could tell me why my bose system in my 2001 maxima se cuts out i have a aftermarket deck and i hooked up the pac-roem nis2 and have a really solid large ground and still it cuts out my deck has 5volt pre out 4 of them and im no rookie to doing this either im stumped ive tried the 707551 and the 707550 and the pac-roem nis2 still it will cut out.
Old Apr 2, 2014 | 08:57 PM
george__'s Avatar
it is a pos
Old Apr 3, 2014 | 10:07 AM
DennisMik's Avatar
I vote for the 11th option - I don't know what I'm doing.
Your description of your problem lacks many details and posting you problem 2 times within 10 minutes is considered inconsiderate. And the big font in your other post is considered to be impolite.
Old Apr 3, 2014 | 11:23 AM
teejay1786's Avatar
pac roem nis2
ok sorry im new to posting but im not a child and im not saying anything impolite im simply asking if anyone knows why it would still cut out like a straight forward answer cause all these forums never finish or are way off subject thats all its hard to get any real solid information it sounds like mostly guessing if anyone has any info it would be greatly appreciated thx. p.s. im not trying to offend anyone but what more details do u need all i have done is replace my hu and install the pac roem nis2 like all these forums said to do but it dont work it does sometimes but still will cut out just the bass sometimes thats all does anyone know what that could be
Old Apr 3, 2014 | 08:47 PM
DennisMik's Avatar
Is it all bass from all the speakers or just the woofer?
Most of the bass you hear comes from the 8 inch woofer speaker mounted in the center of the parcel shelf. Go in the trunk and check out the connections. Being in the trunk, something could have hit it.
If you don't hear any bass from the door speakers or woofer, then you could have a bad pac rolm unit or the head unit could be cutting out. There are bandpass filters in both of those units.
I don't know if the Bose speaker amplifier in the trunk has bandpass filters in it.
But again, any problem could be a bad connection. Check the connectors, not only for being locked together, but that the individual pins are not backing out of the plastic connector. If you have a connector problem it would most likely be in the dash for the head unit connections.
Old Apr 4, 2014 | 11:46 AM
SSJRICH's Avatar
If you searched the forum you would find that the sub woofer cut out is a common problem. If you have an aftermarket HU it usually make the diagnostic of the problem harder. My boss had and aftermarket HU in his 5.5 and his sub works, but doesn't sound right because the output isn't right. He also had cutout initially because the power relay on the main board of the sub amplifier wasn't saudered on well. You probably have a few different problems. I would start by eliminating the sub power relay Turn the stereo on and try tapping the sub with a screw driver. if the sub all of a sudden comes on, you either have a bad sauder on the power relay, or the relay is shot. If it doenst turn on at all, then you might have a dead relay or other. I had 2 problems with mine. The relay wasn't saudered on well, and I had an exposed wire grounding the speaker out.
GL
PS: no respect = no respect on forums.
Old Apr 5, 2014 | 10:47 AM
djfrestyl's Avatar
Suspension Yoda
Sigh...same question posted in the Bose thread in the audio section, and I provided the same replies and end result diagnosis.
Old Apr 9, 2014 | 10:28 AM
teejay1786's Avatar
bose cuts out
thx so much for the replies and very sorry if i was rude just frustrated is all i appreciate what you guys do on hear i really do. also i will be checking all that stuff you mentioned out tapping the sub and i also discovered that who ever owned the car before me had saudered the white wire that goes to the connecter that plugs into the sub there is some sauder on it but nothing running to it should i clean the sauder off and try it?
Old Apr 9, 2014 | 10:50 AM
djfrestyl's Avatar
Suspension Yoda
SAUDER = company that makes furniture. Also, a business school.
SOLDER = A method (v) and also a substance (n) to fuse metal contacts and allow for electrical connectivity.
PLEASE, for the love of anything holy, start using proper punctuation, spelling, and fully thought-out, non-run-on sentences.
You should be READING more than you're posting.
Old Apr 9, 2014 | 11:06 AM
teejay1786's Avatar
so....do u know what that could be.? And why are you being so rude to me. I spelled a word wrong so what people do it on these constantly i thought you guys were here to help no bash on people over the internet that cant do anything about it wow big man u are thx for the help.
so if anyone who actually wants to post about maxima stuff and not have a pissing match please reply thx so much.
um....no this aint the same question actually its not about my bose stereo its a ground coming out the bottom of my car read the post i never asked about my stereo ground it is fine and you never helped me with a end result so what are u talking about everything you told me could have been it was wrong on my stereo thread you said check connections they were fine everything was fine its the ground from the bottom of my car dip ****
and your diagnosis sucked and was bull**** like i said if anyone who actually knows something could maybe tell me where the ground might go thats hanging on the bottom of my car that would be great thx for your replys
Old Apr 9, 2014 | 12:45 PM
djfrestyl's Avatar
Suspension Yoda
Lol. Ok buddy. Good luck.
Old Apr 9, 2014 | 12:56 PM
NmexMAX's Avatar
dot dot dot ...
djfrestyl is a well respected member and also has vast experience in this field, I would listen to him.
No, that ground is not your stereo ground
Old Apr 9, 2014 | 05:08 PM
The_Fixer's Avatar
Is this ground that the guy is whining about that damn ground strap thats attached to the main cat?and he seriously thinks that runs all the way to his radio?
mpbclutch33
Dec 26, 2015 11:11 AM
RealityCheck
Oct 2, 2015 06:34 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
