02 maxima abs problem
Old Apr 10, 2014 | 06:30 PM
Ispeedbyu's Avatar
I have an 02 maxima and I have been chasing this abs issue for more than 8 months and finally decided to fix it myself. Is this abs ring in the right place or should it be further down the hub towards the sensor?
https://www.dropbox.com/s/7am7e8gp4x...410_181506.jpg
https://www.dropbox.com/s/gv7wu7mv9b...410_181549.jpg
https://www.dropbox.com/s/erj320h7j1...410_181601.jpg
Old Apr 10, 2014 | 10:59 PM
zenjia 03merlot's Avatar
what codes are you throwing, if any?
check the FSM, AX-20. it has specs on the clearance between abs sensor ring and hub. check your electrical connectors/harnesses, check wiring for shearing, cuts, fraying, check for debris in between abs sensor and abs sensor ring, check sensor ring for damage/cracks. could be your abs sensors itself. make sure you use some kind of dielectric grease, makes disconnecting/connecting harness much smoother, plus it protects connections from environmental elements.
Old Apr 11, 2014 | 10:31 AM
DennisMik's Avatar
From the photo, it looks about right, but you need to pull the wheel hub off to measure. The specification is .5 inch from the edge of the wheel hub. The directions are in the BR (Brakes) section on page 139. It is also in the AX (Axles) section as zenjia pointed out, but the page number in the 2002 FSM is page 19, not page 20 like in the 2003 manual.
Old Apr 11, 2014 | 12:50 PM
FanaticMadMax's Avatar
the front will be on your CV axle, looks like gear rings the rears will be on your hub bearing assembly which is typically what Nissan called it tone ring.
Old Apr 11, 2014 | 06:47 PM
i agree with DennisMik and ty for the clarification between FSM-'02 vs.'03, looks about right. tone ring/sensor ring is soft metal, could get damaged, but where it's situated on the rear axle/hub, imo seems rare, throwing my guess towards the abs sensor and/or connection.
Lakersallday24
Nov 7, 2024 07:31 PM
Samedi
Aug 13, 2015 04:05 PM
Hawkeye61
Aug 12, 2015 06:45 PM
yat70458
Aug 3, 2015 01:16 PM
