I want to install new headlights...
Old Jan 20, 2002 | 07:29 PM
silentbuzz's Avatar
Hey people, I want to install new headlights, you know the blue/white ones. I thought I could drop them in, but I noticed the rigid ball in front of the current stock light. Does that same piece fit it front of my aftermarket one? Let me know,
Old Jan 20, 2002 | 07:37 PM
JimmyH's Avatar
Dont buy blue bulbs. They suck. Trust me. I had Hyper, Krypton, and PIAA. They all are horrible in the rain or fog. And the glare is horrible to others.
Shell out for a true HID kit. Unless you really want to shell out for the 2002 Maxima HID units.
But the Nissan HIDs arent that much better than the halogens.
For what it's worth.
Old Jan 20, 2002 | 07:41 PM
silentbuzz's Avatar
i thought so, but i was bored...still, how did u do it?
Old Jan 20, 2002 | 07:51 PM
JimmyH's Avatar
I bought a kit from speedlights.com. The hid capsules are custom made to fit in the h4 opening keeping the arc in the same place where the filament would be in the h4. You just have to mount the ballasts somewhere. I mounted the passenger side ballast next to the rad. overflow bottle. There is a tapped hole right there and I just attached to it using an L bracket. The driver side I also used an L bracket and attached it to one of the mounting holes that fuse box in front of the battery used. You plug the stock headlight harness into the ballast using supplied adapters, and that's it. note that the stock harness is -12V, so the positive leads on the ballast get plugged into the ground lead on the harness, and vice versa. Not difficult. Took me a couple hours. The worst part is mounting the ballasts.
If you are really serious about it, let me know I can send you pictures. Also note, you give up high beams. I mounted some driving lights to take their place. No where near as bright, but I used the high beams almost never anyway.
One other thing, those coated bulbs have a ridiculously short life expectancy. Xenon capsules are alleged to outlast your car.
Old Jan 20, 2002 | 09:58 PM
zman187's Avatar
I have the PIAA platnium super whites and i love them not too much glare for others and havent' had any troubles yet with them( on wood)
Old Jan 21, 2002 | 12:00 AM
radpp16's Avatar
Re: I want to install new headlights...
Upgrade your harnesses and buy overwattage PIAA PLatinum Superwhites...
hey my NIssan OE headlights are better than Halogens.....
Roger
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
