p1122 & p2135
Old Jun 20, 2014 | 06:18 PM
95VQ30's Avatar
75mm NWP Throttle p1122 & p2135 HELP
These are codes for the Throttle Position Sensor.
I have the NWP 75mm BBTB kit and was wondering if anyone else has had this issue?
Story goes...
I was driving to work yesterday(doing about 65 in 5th) when all power to my car just died. It felt like the clutch just popped out and I was getting extremely sluggish throttle response. I think it as limp mode. So I pulled over and called a tow truck. While waiting for the wrecker, I was able to start my car and throttle response came back and the car runs fine but I am stuck with 2 SES codes- p1122 & p2135
I just cleaned the MAF and checked all my connections. They checked out. So I have also done the idle relearn procedure about 5 times with no avail.
So question remains- Has anyone with the NWP 75mm throttle body had an issue with the throttle response sensor? If so, did you replace the part or get a new TB?
All help and input is greatly appreciated.
Last edited by 95VQ30; Jun 22, 2014 at 09:34 AM. Reason: Changed title- Trying to get some feedback
Old Jun 23, 2014 | 03:55 AM
95VQ30's Avatar
Bump. Anyone?
Old Jun 23, 2014 | 08:32 AM
colt149's Avatar
p1122 & p2135
P2135 throttle/pedal position sensor/switch A/B voltage correlation refers to a problem related to the throttle's ability to open and close properly
DTC P1122 ELECTRIC THROTTLE CONTROL FUNCTION
Read this
http://www.nicoclub.com/FSM/Maxima/2002/EC.pdf
Check the throttle control relay.
Try to contact NWP engineering and request for a replacement. ( lifetime warranty if you bought it directly to them) the main problem I believe is the throttle body
Good Luck.
Old Jun 23, 2014 | 04:47 PM
95VQ30's Avatar
Contacted Aaron via email and it looks like there is an issue with some of the harnesses from voltagedrop. Aaron has developed a new harness and is replacing it free of charge.
NWP FTW!!!
BigFly_2K2SE
Feb 22, 2016 10:23 PM
a34max
Jan 12, 2014 12:43 AM
jeff5347
Sep 24, 2010 11:28 PM
