2001 Nissan Maxima -Transmission- Revs Rise, Speed does not
Old Jun 23, 2014 | 12:03 PM
District's Avatar
2001 Nissan Maxima -Transmission- Revs Rise, Speed does not [SOLVED]
When driving for a period of 40 minutes +, usually on the highway, my 2001 Nissan Maxima transmission begins to "slip" (if you can call it that). Randomly, the car would fall into "neutral", and as I press the gas pedal down, the revs begin to rise to 5000-6000 RPM's, but the speed remains unchanged. To fix the issue, I shift into neutral, 1 or 2, slow down, and drive again but very carefully as to avoid further "slippage".
I do not have a "Check Engine Light", and this has happened to me three or four times, but it seems the frequency may be increasing because of the summer heat.
What do you guys think is the problem? If you have experienced this before, how did you fix it? What can I tell my mechanic specifically to look out for?
My problem is exactly same as the one portrayed in this video on youtube.
Thank you ahead of time.
SOLVED: My mechanic picked up the P0720 code on the diagnostic and we quickly replaced the "Speed/Revolution Sensor" located behind the wheel on the drivers side. Cost me $75 for labor and $119 for the sensor. The sensor was a bit expensive, could have picked it up for maybe half the price online, but I did not want to wait any longer to have it changed, since the slipping could have damaged the transmission very badly.
Old Jun 23, 2014 | 10:13 PM
BronxSleeperMax187's Avatar
You do have A CEL on from the video I see.....jk
Might be the revolution speed sensor, had A problem once like that and that fixed the slipping in the summer heat. Google this.... DORMAN NISSAN MAXIMA REVOLUTION SPEED SENSOR...$77 bucks online
Old Jun 24, 2014 | 04:49 AM
District's Avatar
That is not my video. On my car, there is no CEL.
Could it be the Speed Sensor even though there is no CEL?
Old Jun 24, 2014 | 05:04 AM
D.Stillwell's Avatar
You know what, on my old 2001 I30 I had this same problem, it was very intermittent and definitely happened when really hot out.
I definitely remember my speed sensor going out shortly after this happened a few times, doing that sensor fixed the problem, and then a second speed sensor went out. After those two that problem never happened again and car had 150k at the time.
Old Jun 24, 2014 | 05:39 AM
District's Avatar
Do you remember if your CEL was on? How did you figure out which sensor was it? I am at my mechanics shop right now and they are telling me that it can not be a sensor because the CEL has not come on.
Old Jun 24, 2014 | 10:21 PM
Don't listen to the mech.....change the one I told you lol. So many trannys have been rebuilt cause of this.....awwww $$$$
Old Jun 26, 2014 | 04:47 PM
QueensMAX's Avatar
I've seen this alot too!
ah2002
Mar 9, 2016 01:42 PM
xUNIxPanther
Aug 27, 2015 10:09 PM
District
Aug 15, 2015 08:23 PM
09maxshawn11
Aug 14, 2015 10:07 PM
niZ
Aug 7, 2015 10:18 PM
