are my engine mounts electronic?
Old Jun 28, 2014 | 08:52 PM
maximasicilian123's Avatar
I have an 02 and I wanna replace my mounts. Should I go oem ? How do I know if they're electronic?
Old Jun 28, 2014 | 09:22 PM
george__'s Avatar
Is your car AUTO or MANUAL?
Old Jun 28, 2014 | 09:54 PM
Manual 5.5
Old Jun 28, 2014 | 09:55 PM
maximase86's Avatar
I love lamp.
Nope, they are not.
Old Jun 28, 2014 | 10:41 PM
george__'s Avatar
Consider stiffer mounts!
Old Jun 28, 2014 | 10:50 PM
CMax03's Avatar
ES insert or Red Lion Racing!
Old Jun 28, 2014 | 11:27 PM
Are these just bushings or is it direct swap I can do on my own without a press?
Old Jun 28, 2014 | 11:29 PM
Since they aren't electronic should I be worrying about the ecu burning out if they go bad? Thats the only reason I wanted to replace them now but I have so much other **** I gotta do I rather not if I don't have to.
Old Jun 28, 2014 | 11:36 PM
george__'s Avatar
why the f8k would your ecu burn out buddy
Don't worry about it if you can't afford it
Old Jun 28, 2014 | 11:45 PM
Never mind I forgot who im talking to
Old Jun 28, 2014 | 11:53 PM
george__'s Avatar
Lol.
Your ecu won't burn out but other damage could be possible
Old Jun 28, 2014 | 11:59 PM
Your full of good info
Old Jun 29, 2014 | 12:00 AM
george__'s Avatar
Just trying to help.
Old Jun 29, 2014 | 12:03 AM
From what I read bad motor mounts mess up the iacv and burns the ecu out I just don't know if non electronic mounts do it too
Old Jun 29, 2014 | 12:13 AM
george__'s Avatar
Auto came with electronic but you can unplug them or not use them whatsoever like in my case...
What mileage is your car?
Old Jun 29, 2014 | 12:22 PM
colt149's Avatar
engine support
Maxima 2000-2003 with manual trasmission: have front and rear NON- ELECTRONIC engine support. My advised is to replace the front with OEM Genuine NISSAN engine support. The rear one, your preferrence. Replace
Motor Subframe Bushings - Front Mount with Energy suspension.
http://www.energysuspensionparts.com...sp?prod=7.1116
Why OEM in front, the aftermarket Engine support will give a lot of vibration on the vehicle. I replace the motor subframe bushing on my vehicle and I feel minimal negligible vibration but it compensate on stability and excellent control in high speed.
Old Jun 29, 2014 | 08:47 PM
Those gotta be pressed in? Just replace the bushings?
Old Jun 29, 2014 | 10:01 PM
CMax03's Avatar
You don't need a press! Cut them in half and insert each side then install the bushing for the bolt and they aren't going anywhere once assembled on the car! Or use your car as the press!
Old Jun 30, 2014 | 07:52 AM
djfrestyl's Avatar
Suspension Yoda
Seriously? Use a car as a press? Find someone with a press. Do it right. You will need a press to get the old ones out.
But to the OP, there is NO RUSH to do your motor mount bushings. You do not have electronic mounts, thus, there is no risk to your ECU.
wyobbagy
Jan 3, 2023 12:03 PM
derekinthez
Nov 13, 2022 04:00 PM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
spidgeon
Sep 9, 2015 03:36 PM
