2000 Maxima hard to start, stutters and stalls when started
2000 Maxima, does what the title says. Took it to a mechanic. He says it's the starter motor. It can throw the timing off. I've never heard of such a thing. Any thoughts?
kjhansen
kjhansen
has the transmission been removed for any reason? if so, the mating surfaces of the engine and trans should have been sanded down, and if not can cause this issue
also check the ground cable from the battery, make sure its connected to the block.
When the problem started? Any recent repairs? Any codes? SES is lit? Can you hear fuel pump building up pressure when you turn key to ON (but not to START)?
kjlouis
11-24-2018 06:09 AM
