Squeaky belt? bad idler pulley?
Old 07-31-2014, 08:01 PM
02nissmax's Avatar
Hey all,
I've had a squeak which seemingly appears to be the belt. I made sure it's tight and I put a little bit of grease. I forgot what I used for grease as advised by the auto part store. They said not to use belt dressing because it sucks to use a dab of grease on the pulley, but this didn't resolve anything.
The squeak usually comes on in the morning and then as the car warms up it goes away, Do you guys think it's a bad idler pulley? What's common to squeak on these cars?
02nissmax is offline
Old 08-01-2014, 07:48 AM
2damax's Avatar
Replace your belts.
2damax is offline
Old 08-01-2014, 09:32 AM
eclivic's Avatar
Originally Posted by 2damax
Replace your belts.
While your down there, check all component pulleys for drag or bearing grinds
eclivic is offline
Old 08-01-2014, 01:36 PM
colt149's Avatar
squeaky belt
Temporary removal of squeak : Use a candle and rub it along the side of the belt.
Permanent fix: replace the drive belt.
colt149 is offline
Old 08-01-2014, 05:47 PM
Puerto Rico-Maxima Lover
Lontar1's Avatar
get the OEM belt and the noise will go away, good luck
Lontar1 is offline
Old 08-02-2014, 09:52 AM
Jaison's Avatar
just remember that the tensioner is reverse threaded. so lefty-tighty righty-loosy lol
Jaison is offline
Old 08-02-2014, 08:42 PM
02nissmax's Avatar
Thanks all for the tips, hopefully those pointers will get this damn squeak to go away.
And Jaison thanks for the reminder. I do remember once taking this damn tensioner off and trying to go left with it and wondered why it wasn't coming off lol
Old 08-04-2014, 09:16 AM
02nissmax's Avatar
Actually must've been a diff car. On my 02 left is loose and right is tight for both bolts
Old 08-06-2014, 02:23 PM
dot dot dot ...
NmexMAX's Avatar
NmexMAX is offline
Old 08-19-2014, 06:01 PM
02nissmax's Avatar
Replaced the belt and pulley and all good now.
Thanks all
Old 09-04-2014, 04:36 AM
tinymotoking's Avatar
Same issue
My question is how to check the pulleys. just turn 'em by hand and feel for grinding and drag?
tinymotoking is offline
chisam14
11-06-2018 08:56 PM
06-06-2017 02:01 PM
Unclejunebug
04-02-2016 05:42 AM
HerpDerp1919
09-29-2015 02:02 PM
Andy29
09-29-2015 05:32 AM
Quick Reply: Squeaky belt? bad idler pulley?
